Results 11 to 20 of 1640
November 24th, 2010 12:22 PM #11
Stebel GP2 compact airhorn
From down-firing:
To front-firing (to really "get the message through"):
DLAA LA8050 auxillary lights (reverse camera aid):
November 24th, 2010 12:30 PM #12
ok yan sir ah parang may spot light sa likod clear na clear pag nag backing hehehe
November 24th, 2010 12:40 PM #13
November 24th, 2010 01:55 PM #15
* sir doy
useful talaga yan bro especially if may mga wow legs naka tayo sa likod ng tail gate. kitang kita yan sa front monitor mo!
yung horns mo bro parang barko na ata yan ah? hehe.. gusto ko nga din dagdagan ang bosch horns ko with another set of hella horns.
- Mar 2003
- 124
November 24th, 2010 05:39 PM #17
Mahina sya compared sa real train horns with metal trumpets and tanks na aabot ng 100-150psi. Around 15psi lang ang mga compact air horns gaya nito. Pero it's still louder than electric trumpet horns. Kung yung Bosch (I'm assuming it's a Europa) mo is mounted sa front grills and facing forward, you could add another set and have them facing the ground or sa sides. I noticed kase na electric disc horns are loud when you're infront of the horn but poor on peripheral dispersion. You could go for Roots. Halos pareho ang tunog ng Megasonic nila sa Bosch Europa pero medyo affordable yung Roots. Yung Hella Supertone iba kase ang tunog at di gaano kalakas (kahit 30amp yung fuse at relay with gauge 14 wires).
November 24th, 2010 05:47 PM #18
November 24th, 2010 05:50 PM #19
- Oct 2009
- 158
Automatic po Sir
