Page 22 of 22 FirstFirst ... 121819202122
Results 421 to 429 of 429
    May 2010
    #421
    hi philmagi.
    i believed in what ur tellin. we done d same experiments and we did separate the gas we desired. the gadget was simple, made of ss plates and a simple circuit. can u give me a better throttle control circuit? i want to build my own circuit. you are more advanced as you have more sensors. thanx a lot.
    xxxpider
    Jan 2011
    #422
    anybody with HHO sa EFI engine.
    EFI engine kasi ang Car ko, nu ba dapat gagawin, di ba my computer un sa loob? do i need to adjust the Idling of the EFI? please share naman ang experience niu sa HHO in EFI engine, Toyota Revo EFI
    thanks! concern kasi 60Php na ang gasoline
    Aug 2007
    #423
    Hi mjparco,
    I am not sure really if anyone is able to really setup HHO properly. If you notice, the last entry in this thread before yours was more than a year ago, and they were all talking about experimental stuff. I suggest you consider converting your engine to run on LPG too, at least that one is sure to work with many people having tried it, and there are a lot of service and parts available for it. With a huge space like a Toyota Revo, you can put an lpg tank inside and still have a big space for your cargo.
    Jan 2011
    #424
    Help,
    Im will put HHO in my Toyota Revo GAS EFI
    How can I fool the O2 Sensor of this engine. What I need to buy.
    I dont know what king of o2 sensor is Toyota Revo, Single wire or double wire? Narrow band or wide band?
    Please help for some information so that I can fool the o2 sensor of the EFI.
    Thanks!
    Aug 2004
    #425
    Buy an APEXi S-AFC, and retune your air-fuel ratio. The Revo EFI is a gas guzzler because it's literally drowning in gasoline at low rpms. Using an air-fuel controller will enable you to cure this without using HHO hocus pocus.
    Tuning an EFI engine isn't just guesswork and good wishes... if you really want results, you will tune it against an air-fuel meter and with operating temperatures in mind, instead of altering its operating parameters with no clear idea of what you're doing or how and why what you're doing will work or not.
    Mar 2007
    #426
    Quote Originally Posted by mjparco View Post
    Try doing a research... I suggest you google search GEORGE WISEMAN of EAGLE RESEARCH INSTITUTE.
    Mar 2013
    #427
    this HHO hocus focus has been helping lots of small people cut their gas consumption to as much as half and this was just featured in channel news asia.
    Oct 2009
    #428
    Kokontrahin lang yan ng mga big oil companies...idedeclare nila yan na hoax.
    Aug 2004
    #429
    It's the same question as always... can you show proof in real world testing? In a controlled environment or situation, like on the dyno?
    Until then... no thanks.
Water as Fuel / HHO Technology [Merged Threads]
