Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Pick-Ups, Trucks, Buses and Other Vehicles Talk Thread, What is Your Fastest Speed using a Diesel Vehicle? in Car Talk; Originally posted by rsnald quote:Originally posted by jondy fellow isuzu owners, kaya ng xwind 130 4th gear @4250 ang sa ...
Page 6 of 85 FirstFirst ... 23456789101656 ... LastLast
Results 51 to 60 of 844
Like Tree1Likes
Thread: What is Your Fastest Speed using a Diesel Vehicle?
  1. #51
    Tsikot Member Rank 4 x-wind's Avatar
    Join Date
    Location
    paranaque
    Default
    ang sa fuego nmn 120 4th gear @4250
    quote: xwind
    like this speed..............5th gear na ko di ko pa maabot ito speed na to........
    @jondy
    matindi pala si jondy, hi revver ka pala pre . ako, napaabot ko lang ng 4250 rev ko nung na-stuck ako sa putikan, ginamitan ko ng primera sabay hataw. buti na lang rear wheel lang na-stuck.
    @xwind
    pre, you need a loooooooooong stretch of road to get to 140KPH. One time ko lang na-reach yang speed na yan, sa NLEX. Nag-start ako sa dun sa viaduct. tapos lampas nako ng viaduct di ko pa rin nareach 140, saka saglit ko lang nakuha. ala pang 1 minute ata. then I had to slow down, kakatakot e, dami ng sasakyan.
    120-130 kaya yan sa SLEX. Pero I seldom do it. 100-110 kph lang ako, 120 if I need to overtake.
    yup nakuha ko 130 before sa star hway after that di ko na ulit ginagawa mahirap na minsan lang disgrasya..........ngayon 100 na lang ..................
  2. #52
    Tsikot Mindanao Chapter Moderator
    Join Date
    Jul 2003
    Location
    ipil, zamboanga sibugay p
    Default
    x-wind,
    nsa 15K ang set kasali na ang installation. medyo mahal nmn pero sulit na kc tipid pa sa crudo. i can do 22K/L nung na install ko.
    rsnald,
    kailangan mo i high rev ang mga isuzu kc nandun tlga yung power nila, na notice ko kc pag nag shift ako 3,000rpm hirap mag 130. pero now easy nlng ako nagpapabilis lang ako pag may emergency.
    may mga members ba tayong nag ddeal ng biodiesel?
  3. #53
    Join Date
    Location
    paranaque
    Default
    x-wind,
    la ka bang load dito and off aircon nito.........22k/l wow ok to..............sa akin kasi 13.8 km/l lang o tipid ka talaga......
    *edit: Inayos ko lang po, medyo nalito ako sa reply line nyo.
  4. #54
    Join Date
    Location
    paranaque
    Default
    sir try to call nena of sharkis
    tel:02 8441643 & 02 8440979
    some client nila sa dipolog pag nagpadala sila shipping lines and forwarders very cheap lang daw yun fare.
  5. #55
    Join Date
    Location
    pasig
    Default
    93 pajero gen 1 turbo 135kph
    00 kia Carnival TDIC A/t 165 kph
    Both sagad na. at NLEX during its better days
  6. #56
    Join Date
    Jul 2003
    Default
    83 MiniCruiser Jeep with Mazda RF Engine 120 kph in 5th gear. Mukhang kaya pa ng makina pero mukhang hanggang doon ko na lang susubukan at baka liparin ang kaha ko hehehehe.......
  7. #57
    Tsikot Member Rank 4 rsnald's Avatar
    Join Date
    Location
    samwer awt der...in luzon
    Default OT HOw to compute topseep based on RPM
    For the mathematically inclined and geek at heart....
    just a little math trivia ... I found this article while browsing for explanations of gear ratios.
    You can compute your estimated top speed pala based on your engine RPM provided you have the following data :
    1. wheel data on rim diameter, width and aspect ratio.
    #1 makikita mo to sa gulong mo
    2. transmission gear ratios for the different gears.
    3. gear ratio of the rear axle.
    #2 & #3 you'll find in your car manual.
    you then use the equation below to compute your
    Speed (in KPH) = RPM x wheel radius /(Final gear ratio x 105)
    example... for my XTO crosswind.
    wheel data : Yokohama 205 /65R15
    R15 = means 15 inches rim diameter
    205 = means 205 mm width
    65 = means tire height is 65% of width or = 205 x 65% = 133.25 mm height
    to get wheel radius then
    radius = rim diameter/2 + tire height
    =(15/2) inches+(133.25/25.4) in
    = 12.75 inches
    transmission gear ratio data:
    1st gear : 4.122 ..... etc. etc.
    5th gear : 0.855
    rear axle gear ratio = 4.1
    to get final gear ratio... simply multiply rear axle gear ratio x transmission gear ratio
    for example, in 5th gear, final gear ratio = 4.1x 0.855 = 3.5055
    in 1st gear = 4.1 x 4.122 =16.9002 etc. etc.
    to get your speed at 4250 rpm (redline ng XTO) in 5th gear then..
    speed = 4250 x 12.75 /(3.5055 x 105)
    = 146.7 or about 147 kph.
    147 kph pala ang topspeed ng XTO at redline in 5th gear assuming no assistance from wind or downhill acceleration.
    the computation is quite accurate. It correctly predicted my speed at 2900 rpm in 5th gear - 100 kph. yung ang RPM ko when i'm cruising at 100 kph. even in other RPM's the calculated and actual speed medyo nagtutugma.
    oks ba or nahilo kayow?
    for a full explanation... see
    http://www.geocities.com/MotorCity/7080/TIP094.html
  8. #58
    Join Date
    Location
    paranaque
    Default Re: OT HOw to compute topseep based on RPM
    = 12.75 inches
    5th gear : 0.855
    buti na lang pareho kami ni sir rsnald di ko na kailangan mag compute.
  9. #59
    Tsikot Member Rank 4 HBOY's Avatar
    Join Date
    Location
    From all the boards....
    Default
    i can attest to the power of the Trooper... nagouting kami last year ng office namin.. dala ko yung Honda City ko... going back to manila from batangas... we got in the star toll... nagkaroon ng hidden understanding na hatawan na... e di tapak sa silinyador... at 165KPH (on my speedo).. magkatabi pa rin kami ng trooper... gulat ako dun.. considering.. minamaliit ko pa sya nun dahil diesel.. e kung umarangkada eh kala mo gasolina....
    I know.. i know.. 1.3L lang ako... but still.. that is one hell of a diesel engine!!!.. BOW ako dun.. i had to back off.. natatakot na si kumander at floaty na yung city at speeds above 150KPH.
  10. #60
    Tsikot Member Rank 3
    Join Date
    Jul 2003
    Default
    dun sa calculation ng top speed mali pa rin yun cuz if i use that, since 38 ang gulong ko compared to the 31 ng standard patrol dapat top speed ko 10 kph faster than an ordinary patrol but then reality kicks in and makes me realize that the bigger my tires the more torque it takes to turn plus the fact that bias ply ang gulong ko = more torque needed. then add to that the fact that bubbles looks like a box, forget aerodynamics, then the greater fact that i'm about 1 ton heavier than a standard patrol. all in all it adds to hmmm... a 90 kph top speed.
    not all vehicles can reach the redline at fifth gear. buti kung downhill.
Receive Latest Cars For Sale Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
