Results 1 to 7 of 7
May 9th, 2007 08:17 PM #1
sir, patulong naman po... i have this "kalantsing" sound sa may transmission, narinig ko po 'to the day after na pinatakbo ko ng sobrang bilis yung car.. what would be the possible causes of this sound? delikado npo b non? tnx a lot...
*kapag tinatapakan po ung clutch nawawala po yung sound...
May 14th, 2007 11:49 PM #2
kung RWD ka. Check your spider(cross), part of the universal joint. Check for looseness,kung may nipple siya just pump grease.
May 15th, 2007 08:55 PM #3
sir,FWD po..thanks po sa reply..pinacheck ko na po s mekaniko,kinabahan napo kasi ako..he said naubusan daw po ng gear oil, natuyo po, tumalim nga po yung mga ngipin ng gears..sabi niya isang byahe pa, sasabog na yung mga gear..nawala po ung snap ring,lock nung axle, kya daw po nagkaroon ng leak..ngayon po ok napo siya..wala napo yung ingay..thanks po..
May 15th, 2007 11:13 PM #4
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 16th, 2007 12:03 AM #5some will have a dipstick lalo na kapag auto. you can pour in through that. either that or through a filler hole or through the speed sensor.
May 16th, 2007 10:49 AM #6
nope,hindi po siya atf..just like what sir speedyfix had said, there is a filler hole mainly in the transmission where you can pour the oil..hindi ko po alam sa mga bagong auto ngayon kung meron ng lalagyan for the g.oil, just like for the brake fluid...medyo oldies na po kasi auto ko tapos newbie pa po..
my 19 yr old car .. as in naka 3M .. walang palitan.. maganda sa old 3M ng car namin as in hindi...
