Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Other Troubles Thread, RPM fluctuating.. in The Workshop; 1) honda ek96 ang ride ko mga bro's. napansin ko lang since last week na nag pa-fluctuate ung rpm ko ...
Results 1 to 8 of 8
Thread: RPM fluctuating..
  1. #1
    Join Date
    Aug 2005
    Default RPM fluctuating..
    1) honda ek96 ang ride ko mga bro's. napansin ko lang since last week na nag pa-fluctuate ung rpm ko from 1 to almost zero kapag nakatigil ako, minsan namatayan pa ako.. pero once na matagal na tumatako ung car eh wala naman.. ano kayang problema?
    2) possible kaya na apektado rin ung aircon ko? kasi minsan on and off ung lamig nya hindi na consistent, nag aamoy humid tapos after 10 to 20 mins saka lang lalamig... kakatapos ko pa lang mag pa cleaning ng aircon pero ganun pa rin ang problem. nagpalit na din ako ng relay nya baka kasi ung switch ang problema.
    Need your help and suggestions guys! maraming salamt in advance!
  2. #2
    KBR
    KBR is offline
    Tsikot Member Rank 3 KBR's Avatar
    Join Date
    Dec 2007
    Location
    Vallejo, California
    Default Re: RPM fluctuating..
    Quote Originally Posted by Nash26 View Post
    hey bro, you might wanna check out your IACV (Idle Air Control Valve..) also, the TPS (Throttle Position Sensor..) can cause an eratic Idle.
    and about your A/C.. make sure na puno ang A/C condenser ng refrigerant. since malamang konti lang ang na ilagay nila sa A/C mo. so you might wanna have that inspected.
    aite, peace.
  3. #3
    Join Date
    Nov 2006
    Makikisingit na rin po regarding rpm.Sakin naman is nababa sya from 1000 to 800 when i turn on ung headlyt pero di naman namamatay ung engine.So sa araw steady lang sya sa 1000rpm which i think medyo mataas from normal dba.Before di naman ganito auto ko(ae101) ano po kaya dapat ko ipacheck.thanks and good day to all.
  4. #4
    KBR
    KBR is offline
    Join Date
    Dec 2007
    Location
    Vallejo, California
    Quote Originally Posted by three in xe View Post
    about sa engine RPM going down when the headlight is on. well I would suggest having your Alternator checked. tingin ko "ok" pa siya for now (since hindi ka panaman namamatayan ng kotse!) pero I'm pretty sure na nag we-wear out na ang Alternator... or kundi may mahinang Ground sa Charging system. check the Battery too since it might be charging low.
    also, idling at 1000 rpms is kinda "alright". pero mas maganda pa din pag nasa 900-800 rpms ang idle speed. well, what you can do is check the Throttle Body if its sticking (check mo sa loob.. it might be sticking due to gum & dirt), then check the Throttle Cable and the Idle speed adjustment screw (kung meron).
    aite, peace.
  5. #5
    Join Date
    Nov 2006
    Thanks KBR for the info.Anymore input there mga gurus.
  6. #6
    Shahn - the WORD among US CLAVEL3699's Avatar
    Join Date
    Location
    pasig
    sa akin ganun din pero nacheck na lahat ganun pa din.
    pwede kaya sa computer box na problem?
  7. #7
    Tsikot Member Rank 2 n5110's Avatar
    Join Date
    1. ganito din naging problema ko dati sa ek ko. throttle body cleaning lang ang ginawa ok na. kung marunong ka maglinis nito i DIY na lang.
    2. na experience ko itong 1&2 ang problema pala yung condenser fan nagloloko na, pag high speed ako ok , lumalamig ang aircon pag traffic yan na ang problema erratic din ang rpm. nung pinalitan ko ng condenser fan ayos na. surplus lang kasi sa casa 7k.. pootek
  8. #8
    Tsikot Member Rank 5
    Join Date
    Nov 2003
    clean the tb, iacv and intake manifold.
Receive Latest Car Engine and Tuning Listings Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Engine and Tuning Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
