Results 1 to 7 of 7
- Mar 2006
- 18
May 11th, 2006 06:29 PM #1Hi there,
Just want to verrify what is the meaning of camber?
I had my rear weel check yesterday dahil yung gulong ko sa lilkod sa right side is more in and pasok sa body than dun sa kaliwa.
I notice this dahil most of the time madalas sumayad yung sa left rear-tire ko sa body. It happens pala na medyo nakalabas sya kaysa sa kabila Di katulad ng right weel ko na pasok sya at kahit malubak ay di sya tatama sa body dahil pasok yung gulung sa loob.
I had it check and they said that this needs to be cambered and will cost me 1300-1500pesos for the camber of my rear.
Just want to confirm if he had given me the right details at kung camber ba talaga ang sulution for this prob para pumasok din yung isang gulung sa left side at pumantay?
If yes? Is this worth for the price he asked?
Would appreciate for any comments and suggestions,
Regards,
May 11th, 2006 06:39 PM #2
um... what's your vehicle by the way? and did you already do any modification (shock, spring, bigger tire & rims)?
complete alignment & camber adjustment costs just around P1K at Goodyear Servitek.
- Jan 1970
- 396
May 11th, 2006 06:51 PM #3Originally Posted by mazdamazda
sa minerva alabang mas mura, inabot lang ng 1400 for the same job.
- Mar 2006
- 18
May 11th, 2006 07:14 PM #4My ride is Corolla 90.I have 15"mags on it.and wala naman modification na ginawa dun.
Shocks and springs are good.Hindi lang talaga sya pasok katulad ng isa na kahit loaded di tumatama sa edge.Yung sa right lang kc naka labas kaya tumatama sya sa edge madalas pag loaded at turning right going up to a parking lot.
Does this has to do with camber?
I'm from Q.C. by the way.
May 11th, 2006 07:42 PM #5
Sounds like it. Camber refers to the tilt of your wheels from top to bottom. If the top is tilted in towards the body, this is negative camber, if it is tilted out, this is positive. Most vehicles use either negative or no camber.
- Apr 2017
- 6
April 15th, 2017 08:56 PM #6nagative camber yan boss, kelangan ng adjustment sa strut mo, kung nka mcpherson strut,
April 15th, 2017 09:06 PM #7
youre replying to a decade old thread... hehhehe
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
