Results 1 to 10 of 15
- Jan 2014
- 158
February 10th, 2014 05:37 PM #1Guys need help
I'm hearing a weird sound when accelerating from 1st to 2nd gear (parang tansan na kumakalansing )
but doesnt happen ni rev ko tapos naka idle lang yung car (nuetral )
Only happens from 1st to 2nd gear or basta yung unang pag apak mo sa gas pero after nun mawawala na pag asa 30-50 kph kana or basta continues mo ng apak yung gas
Napa check kona sa mechaniko eh di rin nila alam yung problem best to describe it is parang tansan na kumakalansing rinig talaga sa loob kahit naka aircon or wala
please give advice thank you guys!
- Jan 2014
- 158
February 10th, 2014 07:13 PM #3hindi naman sir same gas lang pinapakarga ko , ( Petron XCS as per the previous owner used before ) yung mekaniko ko lang nag lagay ng super unlead ata yun ng petron(P300) basta hindi XCS nahaluan niya ng ganong gas while almost fulltank pa yung car ko
WHat do i need para mafix to? is this dangerous para sa car? yung weird sound? salamat ng marami sir
What gasoline do you recommend as well for this car?
Toyota Vios 1.5G Automatic 2004 model
- 52,698
February 11th, 2014 12:42 AM #4your description, even your choice of words, is classic textbook for engine ping. agree with the ghost.
try using higher octane fuel and see if it disappears. the octane ratings of the various fuels are posted on the pump. use them as a guide.
alas, i'm not sure what gas your car is designed for..
- Nov 2012
- 10
February 11th, 2014 03:44 AM #5your car is designed to use from 91- 97 octane gasoline ... if u use higher octane , let say 95 mas pino ang takbo at andar ng makina ... take note ung octane rating ng gas pag ngpapakarga ka, don't be confused on whatever names they call it ... and try at least 95 octane ....
February 11th, 2014 05:12 AM #6
Sir, since naka xcs ka na at nakahigh octane as what is recommended sa manual na 91.
First try mo low gear high rpm.
My SA once advise me na carbon deposits iyun from the catalytic converter. Baka sa driving style mi nagbuild up carbon dep sa catcin at may time na pinipurge niya palabas ng system.
Or better yet try to check the catcon.
Imho, xcs has a magnesium additive in replacement sa lead. The deal is same impact sila sa catcon ng lead. - please correct me if i am wrong just heard it in yhe news couple of months ago.
Try seaoil x97 din ng 2 to 3 FT. Then go back to unleaded and try other brands as well.
Ako iwas big three ako. I preffer firat: seaoil, 2nd total and phoenix. For high and regular octane fuels.
Posted via Tsikot Mobile AppLast edited by brainmafia_310; February 11th, 2014 at 05:16 AM.
- Jan 2014
- 158
February 11th, 2014 10:30 AM #7" First try mo low gear high rpm. " <-------- what do you mean by this?
Ok i'll try Seaoil 97 once na nagpa FT ako ubusin ko muna yung laman ng tangke ko ..
Question: WIll it damage my engine if i go a higher octane? Since XCS na ginagamit ko and Seaoil has higher octane right? ( Sorry Newbie talaga ako )
Ang style ko kasi mag rev ng car is slight apak lang sa gas hanggang umabot ng 2nd gear ,so parang low rpm rev going to 2nd gear ,
Hindi ako yung aapakan ng malalim yung gas to rev up to 2-3k going 2nd gear eh . ganon ba dapat?
February 11th, 2014 10:43 AM #8
imho, hindi siguro sa fuel octane yan, baka sa driving style mo.
i have a friend who has the same car as yours and he is using a 91 octane gasoline.
baka sobrang under revved ka kaya napwepwersa yung oto mo on shifting.
try mo mag put ng more revs... usually, pag AT, nag shishift yan pag 2.5k rpm to a lower gear.
- Jan 2014
- 158
February 11th, 2014 10:58 AM #9OO nga Sir medyo di ako fan talaga ng high rev pag apak sa gas going to 2nd gear actually almost 1k to 1.5k rpm lang pang change ko to 2nd gear ganyan ako kahina umapak sa gas minsan below 1k revving pa, bad habit ba?
I'll take your advice I'll rev more higher atleast 1.5k to 2k rev and i will check if it occurs parin thanks sir will post the results asap
February 11th, 2014 01:18 PM #10
Sir maigi din na ipatay mo OD or shift at d3 hayaan mi lang mag 3k rpm ka uo to 3.5k rpm para lang di magkick in 4th gear kaya maghahigh rev ka sa 3rd gear.
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
