Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
    Sep 2002
    #21
    Quote Originally Posted by BlueBimmer
    the m50 and m52 engines have timing chains afaik
    how can one tell the difference between the 2 (m50 and m52)?
    Sep 2005
    #22
    Quote Originally Posted by dx8976
    The lazy way - M52 with the oil filler cap up front, way back for the M50 ... I think There are other ways, of course.
    #23
    How much is it to have the waterpump replaced tsaka yun rear subframe shock mounts? My 10 yr old E36 is ok but if it's a maintenance thing to have those replaced then i'll do that. Naka 70,000km na yun kotse ko. Thanks in advance.
    Dec 2003
    #24
    recently changed my valve cover gasket and had a peek inside..tiptop condition pa pati ang timing chain. 52k kms.
    #25
    Quote Originally Posted by airshaq20
    That is so weird.....i drove my E36 (325is) for just over 2 years and never had a major problem with it.....The only thing that bothered me was the service lamp that lights up and i have to go to a fancy shop to have it reset..i used to change my own oil since i get my Mobil-1 oil real cheap.....but the only thing that i changed was brake pads and the 2 belts.....good thing is that they use timing gear/chain so i never worry about breaking it....aside from that, it was virtually maintenance free in my part (also true with my previous E46).
    Check this Site Reset Oil Service Reset Light http://www.unofficialbmw.com/e36/ele...ce_lights.html
    Nov 2003
    #26
    easy lang to reset the light as long as you have a tool, should't be too expensive pa.
Just came from the CASA, Sira nanaman ang BMW ko!
