Results 1 to 4 of 4
- Apr 2006
- 40
May 10th, 2006 12:32 PM #11. are there ways to prevent or remove oil leaks?
i noticed this because everytime i check my engine oil level, it's surprisngly at very low levels from previous.but i already notice oil leaks...
2. what can i do?
3. how much does it cost i i let this be serviced?
thanks!
May 10th, 2006 01:48 PM #2
Depende yan bro kung nakita mo na source ng leak... Usually kung gasket leaks, you don't lose much oil, pag blow-by ang malakas kumain ng oil.
Toyota is my choice
- Aug 2005
- 2,063
May 10th, 2006 08:26 PM #3to prevent oil leaks replace oil seals or what the call "eliminate" leak.. cheap parts but labor is kinda "mahal"
trace where the leak(s) located
cost would depend on the labor and parts
Tsikot Member Rank 5
- Nov 2003
- 3,849
high idle RPM at engine start
