if feel new, do this in 1-2 weeks ( i did this all)
complete PMS, change oil, oil filter, air filter, aircon filter, fuel filter, sparkplugs (if gasoline)
replace all fluids: coolant, brake, windshield, washer, power steering F, clutch, MTF (if MT), ATF (if AT), transfer case / rear differential fluid (if 4WD), front differential fluid
clean / grind brake pads, bleed brake fluid
wheel / camber / toe alignment (all four tires), replace all tires if necessary (may wear indicator naman tires)
replace all belts: P/S, alternator, compressor and even timing belt + water pump + tensioner + oil seals (if car is 100TK)
replace all bulbs: headlight, parklight, fog, maplight, domelight, gaugebulbs, dashbulbs (just use the orig specs, wag na LED na uso ngaun)
lubricate all joints, door hinges, power window mechanism (there is a specific lubricant for every application)
replace all stabilizer links / rubber bushings / tie rods if necessary
general aircon cleaning, replace filter dryer and freon
waterless engine detailing
underwash
selective undercoat spray ( say for example you changed your tie rod or stab links, spray with undercoat yun mga turnilyuhan)
I have an 01 car. many are advising na I should sell it coz it looks old coz of the paint. I didn't listen, i did all that, and it rides like new now. well it still looks old coz of the exterior, pero ok lang, if it gets me from point A to b na hindi karag-karag feel, i'm good hehe
i'm still waiting a friend of a friend to quote me for complete washover + detailing and rims repaint ;) pero no rush here. it rides good pa naman
I started driving at 16 kasi I don't wanna depend on other people for me to get around. Mainipin pa ko
. (pero syempre si lahat ng owner ng brand new
(At most of the times, - hindi ako natutulog o makatulog, hangga't hindi tuyo at malinis ang sasakyan - even if that means cleaning the car in the wee hours of the night)
