Page 2 of 19 FirstFirst 12345612 ... LastLast
Results 21 to 40 of 364
    here's a funny excerpt on their website:
    BEWARE OF IMITATION, IT MAY DAMAGE YOUR ENGINE!
    or is it beware of the real thing? :bwahaha:
    Aug 2004
    Do car racers need these gadgets? I mean, isn't this created to suit the need of a regular, fuel-expense-burried folks?
    i got this from my email today,
    share ko lang po sa inyong mga nagbabalak....
    To: OldskulMitsu*yahoogroups.com
    From: "sakne" <mpareja*fcpp.fujitsu.com> Add to Address Book
    Date: Thu, 30 Sep 2004 12:39:21 +0800
    Subject: [OldskulMitsu] Fwd: Re: KHAOS Super Turbo Charger
    this is a forwarded message from one of the members of other group
    Date: Wed, 29 Sep 2004 20:46:26 -0700 (PDT)
    Subject: Re: (MAC) KHAOS Super Turbo Charger
    Reply-To: mitsu_adventure*yahoogroups.com
    All, I had this installed in my friend's car and
    here's our finding.
    1. In the demo, they can show that with the device
    installed, consumption is indeed lesser by 40%. They
    are using this using two bottles of coke, and you can
    actually observe the depletion of gas.
    2. However, they have to alter some settings on engine
    timing.
    3. In City driving, this could be effective.
    4. We tried using it in long distance driving, that's
    when we found the difference, the engine is a little
    bit choked, thus it's very hard to gain speed and
    power, consequently, we end up consumming more gas,
    because you have press down the pedal to accelerate
    more. Instead of 600, we spent 800 in gas.
    5. I think they just make "sakal" of the engine, so
    gas consumption is little, but power and acceleration
    was not considered.
    6. Eventually, we return the device, good for us we
    did not paid yet.
    Lesson, when thing is good to be true, it may not be
    true at all..
    ps..if in your case, it work, then I rest my case..
    ----------------- end of email --------------------
    so that you can see the real effects of the said device in an extreme condition.
    as you know, car racers are already using other power enhancing devices in their cars like air filters, mufflers, turbos, etc.
    and like what was posted in the mitsu website - it is just choking the engine. heck, almost any car enthusiast with a bit of mechanical knowledge knows how to tweak his engine to run leaner. why spend 6K when you can tweak your engine to do the same in less than an hour?
    quoted from khaos website:
    KHAOS Super Turbo Charger is the 4th generation PLANAS Super Turbo Charger that has been proven effective for 30 years now. It is designed to give your Engine the "ULTIMATE POWER", Fuel Consumption Efficiency and Pollution-Free Performance.
    Does KSTC affect the engine power?
    Definitely. increased in engine power will be easily felt
    right after the installation because it reach the correct
    mixture ratio of 15 parts of air and 1 part of gasoline and
    so complete combustion was made.
    Is Khaos Super Turbo Charger (KSTC) proven
    already?
    Yes, it has been used by motorist for 30 years already
    and it gone thorough testing conducted by leading car
    manufacturers and government agencies. Results showed
    a saving on gas consumption, increased in engine power
    and brough carbon monoxide level down to zero. (as
    evident by an award winning- Tuklas Award and
    Presidential Most Outstanding Invention award)
    I think the website DOES mention engine power increase.
    Aug 2004
    if that email does experience less engine power, and the website mentioned otherwise, this is a clear case of deceptive advertising.
    Feb 2004
    naku, 30 years na pala ito ginagamit ng mga motorist. mas matanda pa sa akin
    andy
    For sale: Brooklyn Bridge, cheap.....
    Sorry Double post
    Aug 2004
    already?
    Interesting... also note it promises reduced emissions... I wonder how bad they would get, though, if the leaning out causes the engine to bog?
    Many euro-compliant engines and economy-tuned engines sometimes bog down during acceleration due to incorrect mixture conditions, IMHO, if these conditions are exacerbated by the presence of unmetered air, poor emissions performance could occur.
    zero... what vehicle was this tested on? I'd be interested to know if it is carburated or EFI... I'm interested in knowing if you can actually fool an EFI system into leaning out this way...
    If it's possible, then you don't really need the KSTC to do it, you can make one yourself, since the principle is quite simple.
    Or even better, just choke your air filter and muffler... less air entering/exiting the engine means less gas consumed... but it also means very poor performance.
    actually you can fool a typical EFI engine by creating an air intake somewhere after the air sensor. Same results as the KSTC.
    Aug 2004
    So, all I would need for my own Khaos Super Tubo ChargerTM would be an air breather (Simota, P500-P1000), a spring-loaded valve (P150?) to close the Breather under vacuum pressure at higher engine speeds (to prevent power-loss / bogging) and a plastic fitment pipe and rubber seal to fit it all... (under P100)...
    So... what are we waiting for... want to go into partnership and sell?
    ...and we'll name the device "NIKY SUPER-DUPER TURBO CHARGER"
    :exclaim:
    Jul 2003
    sir ghosthunter, kahapon pala nasulat sa isang TABLOID ang KHAOS na dinemo in front of Sir Defensor.... then nagpakabit ang iilang officials pati na ang LTO makati head ata. kasi daw effective ito at sabi rin na tinest din daw ito sa automotive testing center sa taiwan.. sensya na coz nabasa ko lang siya sa pilipinas tonight ba yun hehe nakibasa lang po ako kaya d ko masyado maclear ang details... wala nga lang din sinabi kung panu gumagana
    Aug 2004
    :car:
    Php 3,500 lang for the first 15 customers. Pag kumagat kayo, I promise to spend the money on further research and development, as well as more beer. :D
    Tested in Taiwan? The home of the OTHER intake-based fuel saver? The home of the Turbo-Zet computer fan supercharger? The home of the "Fuel Magic" Magnetic intake gas ek-ek? I believe that.
    Jul 2003
    hahahhaa... basta yun yung nakasulat kasi doon eh haha ok ok, akala ko UK based ang turbo zet hehe ewan ko ba, basta para sakin tama na ang stock lahat
    Aug 2004
    :D
    The point is its still in a tabloid and not any reputable automotive magazine.
    How was the testing done? What equiptment? Was a control used? (example: before & after) Who was looking over to see and check if it was being done correctly (preferably someone with competent knowledge of cars).
    Feb 2004
    drove to davao and back, i am estimating a 12% savings in diesel consumption by having a simple device
    mental rev limiter to 3000 rpm
    libre pa
    andy
    Jun 2004
    yan ang the best ang gamit ni andy. i'm also using that sa slex or nlex not more than 2k rpm
    but what's funny is i bought the Planas thing for my other car. it's 2.0 kasi, curious lang. and i would like to believe na it saves gas para hindi sayang pera ko. hehe...OT yata ako...
Gas saving device
