Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
  1. #1
    Join Date
    May 2005
    Default DIY Rustproof (not undercoat)
    Pwede ba ito?
    You buy the chemical, take off your car's door sidings and spray the inside of the door panel yourself. Then do it with everything else you can reach to.
    Is there a chemical available that we can buy so we can do it?
    Mahal din kasi sa Ziebart at sa Tuff Kote.
  2. #2
    Join Date
    Location
    Singapore
    Default Re: DIY Rustproof (not undercoat)
    It's called Cavity Wax, Wurth has it.
  3. #3
    Join Date
    Aug 2005
    best way for ur problem buy 3m rustproof (undercoat prin rubberize pag tama ang timpla) brush or spray for better finish prang sa casa ang dting
  4. #4
    Join Date
    Jun 2005
    Location
    manila
    before doing any of the above, make sure na wala nang RUST yun metal
  5. #5
    Join Date
    Location
    Singapore
    joey: undercoat is different from cavity wax, you dont apply undercoat into the inner skin of door/sheetmetal panels. cavity wax is the yellow, hardened rugby like layer beneath the car's sheetmetal.
    pitbullz: unless the car has been into a collition, there shouldn't be.
  6. #6
    Join Date
    Aug 2005
    rustproofing ba ang problema or soundproofing? maganda sugestion m kung sound proofing sir saludo ako
  7. #7
    Join Date
    May 2005
    Rustproof lang po not sound proofing.
    Sir theveed where is wurth? Any idea how much is the cavity wax?
    Papano po kung meron ng rust formation, can the cavity wax still help?
    I really intend to do this.
    Thanks po.
  8. #8
    Join Date
    Location
    Singapore
    Wurth is a brand, OEM manufacturer sila of a lot of stuff, kinda like 3M and Bosch.
    Sa Hahn Tools shang sells Wurth stuff, although di ko sure kung meron yung cavity wax. Sure ako meron ang Wurth dahil yung ahente pumunta sa shop dati, kaya lang parang ayaw nila magpaorder hehe, di lagi dumadating tapos kami pa pinapabayad sa shipping.
    You have to remove the existing rust first, kung surface rust lang light sanding + turko or equivalent will suffice.
    http://www.wurth.com.au/cataloguevie...f=A03_0039.pdf
  9. #9
    Join Date
    Location
    Singapore
    Oh I think eto current pic ng Wurth
    Googled for a minute, meron din ibang brand. Not sure kung meron dito.
    But yung libo-libong binabayad nyo sa Ziebart/Tuff Cote eto lang yun.
    http://www.bodyshopwarehouse.co.uk/meta/35.htm
    http://www.chemicar.com/tekton_cavity.php
    http://cms.3m.com/cms/GB/en/2-29/rzcREQ/view.jhtml
    Here are a couple of good sites if you plan to DIY. The info is for "pre-aerosol" days, so mas madali na ngayon. Good pointers. HTH
    http://www.fordscorpio.co.uk/cavitywax.htm
    http://www.morrisminorspares.co.uk/esmworkshop.htm
  10. #10
    Join Date
    May 2005
    Quote Originally Posted by theveed
    sir theveed after sanding and turko ...
    kahit wala na ba na primer paint ?
    spray na lang ba agad ng wurth or much better apply na din ng primer?
    BTW : Thanks for nice links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
