Results 1 to 19 of 19
    mga bro,
    i drive a 1992 Honda Accord LX, US model and is fitted with a Denso compressor (stock).
    this year alone, i've had my A/C system done 3 times by other technicians for cleaning, replacing the freon, drier, expansion valve, etc. lumabas every quarter binabalik ko sa mechanic.
    last week, after my 3rd visit to the shop, nawala ang lamig. had it checked and they said that it migth be the compressor coz the peep hole of the drier is black from the oil.
    they didn't want to touch the compressor coz mahirap daw ang denso parts. suggest that i replace the compressor but if i have it changed with another brand like sanden, they will have to change the bracket and fittings too.
    is it worth bringing my car to denso? i did a back read on some of the other aircon threads, malayo si mang mario where i live; new owners na daw si dankee; i'm inclined to inquire with ceejay's.
    any recommendations?
    TIA
    Feb 2005
    you the other shops as well.
    ask for their opinions and estimates.
    Sep 2006
    hi, i have an aircon shop here in bul, tama sbi nla, pag black oil n ung comp, its better 2 replace it n, either wd surplus or brand new f u cn afford naman, jst same wd other brands, pg black oil, wla n pag asa. its better kung denso dn kbit mo, so not to tamper d original bracket n fittings. Tnx!:nod
    Last edited by theveed; October 18th, 2007 at 04:27 PM. Reason: super bold text and promoting commercials :)
    Sep 2006
    pag surplus comp, including expansion valve & filter drier, flushing, r134, oil etc, it wud cost u around 8.5t, pad bnew mga 18t including ung other parts i mentioned above
    Nice info bro. At least may idea na ako sa cost kung magppalit ako ng compressor.
    Btw, baka mapagsabihan ka ng mga mods natin. Super laki at bold at sms lingo gamit mo. Di advisable kasi ito.
    Jan 2003
    been a long time customer of their shop in makati near magallanes overpass and the one here in e. rod near tomas morato(started when they were still in banawe n. roxas st.)
    medyo pricey but they do a good job, even putting back the unit tama ang salpak, i think Theveed knows the original owners in makati, the one in e rod. was their partner that set up shop on his own but still get supplies from makati. sila gumawa nung 2 hiace. yung una nagtipid ako kasi nga medyo malaki ang quote, in the end hilaw ang lamig kahit anong balik ko sa pinagawan ko, puro palusot lang yung mekaniko. so after a year of his BS, nabutas ulit yung evaporator na kinabit nya so kay denso na ako nagpagawa. ayun parang freezer na ulit yung hiace. so when i bought our 2nd hi ace at nag ka problema na aircon, sa denso ko na din pinagawa sa e rod.
    mahal but you get the quality job naman. pinauwi yung parts na pinalitan, iniwan ko na lang sa kanila dagdag kalat lang sa bahay kasi.
    Aug 2007
    Quote Originally Posted by Josh0027 View Post
    Almost the same ride here pre (Accord94), bought a Surplus NipponDenso compressor recently in Banawe nsa 3500. Then pinakabit ko na lng sa trusted na AC mechanic. As of now ayus nman. Pero suggestion lang if bibili ka ng Surplus mabuti ding ipa-check mo muna sa AC mechanic bago ikabit para iwas problema. Meron din daw sa Panay St. G.Tuazon around 2500 daw ang compressor.
    O.T. na din, ask ko lang kung nagpalit ka na ng 80A battery fuse. Wala ako mahagilap tsk. Thanks!
    Sep 2005
    *autofrost - why are you shouting?
    autofrost - thanks sa detailed info
    impulzz - thanks for the advise on coolmate corp. naka email ko nga si mr vincent tagle of pasong tamo and cathy garcia of alabang branch.
    isip ko nga din na sa coolmate ko dalhin para may warranty. pag compressor lang binili sa kanila and outside labor, walang warranty sa compressor.
    Quote Originally Posted by impulzz View Post
    imported model din ba yung accord mo? di pa ako nagpalit ng fuse ng batt, stock pa rin nakakabit.
    Quote Originally Posted by zeroken View Post
    Sep 2006
    sa mga mods, sorry po, ngayon lang ako nag reply, di ko pa kabisado pagpo post.
    Apr 2005
    had my aircon fixed at denso-coolmate last nov 2005. so far, no problem. not cheap but good quality.
    to those who've given their recommendations, suggestions, comments and opinions, my thanks to all of you
    i left my car with coolmate in pasong tamo for replacement and repair of my a/c system yesterday and will pick it up on monday afternoon.
    maybe the admins could now close this topic.
    Jan 2003
    maybe before they close it you post the outcome of the repair done. i know their work sulit naman.
    sige, will post an FR after i get my car tomorrow afternoon and give it a test drive.
    finally got my car yesterday from coolmate makati. they were supposed to release it last monday afternoon.
    got a call from them monday afternoon. they said that they've done the test run saturday afternoon and was running well. come monday morning, they checked it again and found that there was no freon in the system. they did a leak test and found the source in one of the fins of the evaporator.
    since they didn't have the part for my car, they had to get a supplier to fabricate an evaporator to fit my car. and they it made for R134 specifications. and since they had to wait for the supplier to make a new one, i had to wait for another day.
    tuesday morning i called them to check on the status of my car. they said they're waiting for the delivery of the evaporator. i said fine since i'll be in makati the whole day.
    by 3pm, after browsing at concorde in waltermart, i decided to go to the shop and check on my car and just wait there. when i got there, they were already fitting the new evaporator in to its plastic casing and was told that they only got it about 30 minutes before i arrived.
    i still had to wait for them to finish the installation and charging of the compressor oil and freon into the system. then they told me to get in my car and monitor the coldness. after a few minutes, the inside of my car was freezing! i liked it! the cold wasn't 'hilaw'.
    other items that they changed were the:
    compressor = P18,398.65 (originally almost 20K)
    receiver/drier = P750
    2 Hi service valve = P715
    1 Lo service valve = P357
    14 O-rings = P490
    evaporator = P4500 (fabricated)
    1 aluminum rod = P50
    6 prestiet = P165
    600g 134 freon = P630
    160cc ND oil = P512
    .75L DF141B = P580
    Nitrogen = P190
    Sundries = P55
    welding = P1000
    labor = P2025
    total = P30,418.15
    they gave 6 months warranty on the compressor.
    and as of this writing, i feel like i'm in a freezer. but since it was raining the whole day yesterday and today when i drove from makati to cavite, i couldn't say how it would perform after being parked under direct sunlight. so i'll have to wait til the sun comes out and bears down on my car.
    anyway, i have until april to observe the system and bring it back to them before the warranty runs out. and that's when i would probably say if it's really worth it.
    Jan 2003
    well from my experience with their work. so far lahat maayos naman kahit malaki inabot. yung hiace namin kahit tanghaling tapat kaya na sa #2 fan speed on both front and rear aircon. partida pa yung kasi ang makina ng hiace nasa ilalim ng upuan. pag gabi 1 na lang then thermostat ko sa half or 1/3 na lang.
    yup, naka 3/4 lang ang thermostat ko yesterday on my way back to cavite and i was adjusting the fan between 1 and 2, and mlakas pa rin ang lamig.
    brought my car back to denso this morning. i noticed last night that there was a sound of water, then my friend said the water was dripping on her shoe. checked the carpet and it was wet. the technician didn't push the drain hose all the way out so it would flow outside. all is well again.
Denso by Coolmate - is it worth it?
