Results 11 to 20 of 22
- Oct 2005
- 72
May 7th, 2007 09:42 AM #11redorange > thanks....... do you have idea how many liters laman ng fluid ATF ng Civic .... because I bougth 4 liters of Castrol ATF /III para sa change fluid na gagawin .. ?
thanks;
- Oct 2005
- 72
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 15th, 2007 11:55 PM #14a regular drain/refill will take 3-4. if you want to flush it it will take more than that.
May 16th, 2007 09:24 PM #15
*speedyfix: do we really need to flush po ba? ang ginawa ko po kasi before ay nagpadrain ako 4 liters ang pinalit tapos tinakbo ko ulit.. tapos pa drain ulit tapos fill na naman.. tama ba yun?
Nakita ko naman na naging fresh at maganda ang fluid eh, unlike dun sa first drain and fill.. tingin mo po?
- Nov 2003
- 3,849
May 20th, 2007 11:30 AM #16yup that's ok na. basta ok na yung quality ng lumalabas na fluid you know ok narin yung nasa loob ng tranny.
May 20th, 2007 10:17 PM #17
tanong ko lang guys,
since walang drain plug ang a/t ng everest ko san maganda magpa change ng atf (yung tipong siphon lahat ng fluid) sa may banawe area? and what kind of atf ba ilalagay sa eve ko since walang nakalagay sa manual kung anong klase (Ive read the entire manual twice na and wala talaga naka specify).thanks
May 26th, 2007 04:16 AM #18
question ulit...how often do you drain/change your at fluid?
May 26th, 2007 09:16 PM #20
Wow due na pala ako, magkano kaya ang changeoil,ATF replace and fuel filter for pajero?
Traffic!
