Mga Bro, tanong ko lang. Pwede ba i-DIY yung adustment ng valve tappets? Kung pwede? Me link ba that will lead me to the procedure on how to adjust those? Ang ride ko is Lancer 96 model. Thanks!!![]()
eto ba yung tinatawag na valve clearance / valve lash??? you search the net for a service manual of ur car first. or go to www.autozone.com. meron sila jan manuals kaso html format.
did mine a few months ago. corolla gl 91. downloaded instructions from autozone.com. you'll need basic tools and some special tools depending on the whether ur car have shims or adjusting screws only.
kung screw type, kelangan mo ay screw driver, closed type wrench, and feeler gauge.
kung shims kelangan mo ng micrometer at pambili ng bagong shims. or katulad ng ginawa ko, caliper at grinder lang hehehe
kelangan mo din ng pang ikot ng crank shaft para mahanap ang top dead center.
yung actual na pag adjust depende sa car mo. dito papasok yung service manual.
adjusting the tappets is not something your should practice your diy skills on unless kampante ka. baka sumama lang takbo ng makina mo if you do it wrong.
what's the result if you just forget about checking the clearance of the valves? ano po pala PMS on checking the clearance? i have a 13 yr old ride kasi that i never bothered to check, ngayon ko lang kasi narinig yan about the tappets
have them adjusted by a competent mechanic and you should get a smoother running engine with better power and gas milage.
| Tsikot Car Finder Latest Car Engine and Tuning Listings Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now! |
Bookmarks
