Results 1,081 to 1,090 of 1301
- Oct 2010
- 4
February 3rd, 2011 01:59 PM #1081Guys, saan okay/mura magpascan ng Vectra 2.5 A/T?
Laging may check engine light/electronics indicator, brake lamp fuse check (pero may ilaw naman yung brake lamp, ang nawala yung lighter...) tapos yung konsumo sabi sa screen 2.5KM/L na, from 4.5KM/L!
Pansin ko wala din yung temp readings sa screen. Baka sensor problems? (MAF, oxygen, temp?) O madumi lang?
Nangyari din minsan walang response sa kahit anong gear (D, 1, 2, etc.), pero naka-on parin ang engine, at ayaw umandar kapag tinapakan yung throttle (parang nakatapak ka lang sa clutch at nag-rev kung sa M/T). In-off ko makina sandali tapos start uli, meron na ulit gear!
Pahabol, mga magkano din kaya yung sensors?
Salamat!
- Jul 2009
- 2
February 3rd, 2011 04:11 PM #1082Yup. Paper clip test ang term for that :-) In other forums (AOC & VxON), below year model 2000 yung pwede dyan. For newer models, pedal test ang pwede:
Insert the key in the ignition, then fully depress both the brake and accelerator pedals, turn the key to the second turn position (don't start the engine).. kung san yung mileage is displayed it will display ECN****** (where * is a number from 0-9).. just list down the numbers, yun ang fault code/s ECN000000 means there is no fault code..
HTH
- Jun 2006
- 15
- Oct 2010
- 17
February 5th, 2011 11:59 PM #1084Hi Guys!
What brand is the recommended air filter for OPEL Astra 2001? Do you know where I can buy one?
I saw mine under the hood. Very dirty na. Square in shape siya. Kaya minsan parang sinisunok pag nag accelerate.
Just for maintenance purpose, how often do we change the air filter?
Thanks.
- Jul 2009
- 2
February 6th, 2011 08:10 AM #1085WIX brand gamit ko.. PM mo si tbonegwapito..
Usually sabay ko sa tune-up (every 5k kms yata).. Once pa lang ako nagpalit since nakuha ko yung ride ko :-) wala pa 5k tinakbo since last Dec 2010 lang ako nag.pa-tune up..
Meron din pollen or cabin filter for the aircon naman.. Bilstein naman brand, naka.2 palit na ko since Dec 2009..
- Oct 2010
- 15
February 9th, 2011 09:31 PM #1086Would appreciate if you could list down the parts used, it's cost and where it was bought for future reference. What caused the breakdown? I assume some machine shop work was done? And who did your tranny overhaul? I can sympathize with you. Something similar happened to me 2 yrs ago and my Astra had only done 24k at the time. The water pump pulley gave way, causing the timing belt to slip off, and the valves dropped into the cylinders. Bent valves. Word of advice....when this happens, stop car immediately and turn off engine. Do not attempt to restart.
- Feb 2011
- 19
February 10th, 2011 01:44 PM #1087Hi all, new Opel Astra owner here.
I got it second hand(at the very least) and am really excited about the car.
This will be the first car I bought myself and am hoping the investment is worth it.
I have no worries about the body but the A/T is delayed and jumps when moving from stationary position.
Also, The 3 light does not come on when I switch in to 3.
Any tips for driving a A/T? can i drive it like a manual? go from 1st-2nd-3rd-D?
The car also has 128k on it? should i get the timing belt checked out and how much will it cost? kaya ba ito gawin sa petron?
Thanks!!
- Feb 2011
- 19
February 11th, 2011 04:49 AM #1088
- Jun 2006
- 430
February 11th, 2011 09:50 AM #1089I know I might get a warning for this but here goes nothing:
For those interested in buying an Opel Astra G Caravan click here
- Feb 2011
- 19
February 11th, 2011 11:32 AM #1090
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
