Bro. etian,- regarding your abnormal wear on your front tyres, have them checked for proper camber and alignment.... Naging sakit din iyan ng aming Vanette some years ago...
7303:soda:
7303:soda:
good day po..bought a vannette a week ago.. 1993 model.. sory kung madami ako itanong dito.. ung sa side mirror po ba right mirror lang may control switch (left & right) adjustment?
-san ko makikita ung lalagyan n g tubig para sa windhield washer?
-last po asan ung timing belt banda? gas enginge 2.0 po...
thank you po...
Dec.1983, right mirror lang ang may control switch (left & right adjustment). Ang lagayan ng tubig sa windshield washer ay sa likod, pagbukas mo ng pinto, nasa bandang kaliwa, may bilog or butas dun. Ang Z20 engine ay gumagamit ng timing chain, makikita mo sya kapag tinanggal mo yung takip (oil) sa valve cover.
Question, mga vanette owners..san makikita ang timing mark ng Z20 engine? Di ko kasi makita sa harap (as in harap ng crankshaft pulley). Please help naman..
With regards to overheating problems ng Vanette. I had this problem before with my 1994 vanette. What I did was I had my radiator overhauled (2-rows), then change with fresh water, then installed an 8-blade auxilliary fan. I didn't add any coolant. Ayun..no more overheating. With the A/C on (front & back), my temperature doesn't reach half of temp gauge.
I think that you can control both left and right side mirrors... Will verify tonight....
OT: One thing real nice for this van is that you can pop/lift the rear mirror independent of the rear hatch. Turn the key clockwise to lock the rear hatch and then turn it a quarter more (clockwise) to pop out the rear glass. Real handy when piling stuffs at the back.....
7606:mobile1:
Confirmed that our 1998 Vanette has controls for both left and ride side mirrors.... I just realized that Dec1983's is a 1993 model....
7606:mobile1:
hi gud pm guys/ i have a vannete 96 Z20 gas engine/
mga tols baka pede patulong san ba meron magaling na mechanic n matatransfer nung condenser ng vannette tol lower the temp or pano ba magdag dag ng aux fan.. thanks sa mga makaktulong..
mga pre im from manila pala / sana ung exact location ng shop or name ng mechanic/ sori ah dami ako question/ nga pala pag ba nilipat na ung condenser at nagdagdag na ng aux fan kahit d naba palitan ng 3rows ang radiator?? ok naba nun bababa naba ang temp nun??
Mga Sir at SMdelfin,Tanong ko lang yung second condenser ng A/C na ililipat para di mag overheat ito ba yung condenser na katabi ng radiator? kung sakali saan banda sya ililipat, sira kc ang condenser ko sabi mekaniko balak ko kc ipalipat na. saka may idea k b kung magkano condeser na ito. thanks a lot
Yes, that is the condenser that they usually transfer the location because it blocks the air that is going through the radiator and it 'gives off heat',- it, being a heat exchanger
Mine was relocated underneath the front passenger area, and another auxiliary fan was placed on it.
I am sorry, I do not know how much it would cost. Both of my original condensers are still working fine.
If you are in the SouthMM area, I would recommend a shop in Pamplona, Las Pinas. CeeJay's is the name of the A/C shop and is in the general area of Perpetual Help Medical Center....
7707:band:
Sir SMdelfin, tanong ko lang yun bang second condenser ng a/c ay yung katabi ng radiator ang ililipat, kung sakali saan banda sya ililipat . thanks
Sir CVT , thanks a lot sa advise, nag post uli ako sorry ha di ko nakita yung reply mo. anyway thanks again.
Mga sirs, patanong uli sana regading dun sa A/C ng vanette ko kc lagi na lang nawawala ang lamig medyo marami na ang pinalitan like compressor, 2nd condenser, filter and hose pero di tumatagal after mga 1 to 2 days nawawala uli lamig, medyo malaki na rin ang nagagatos ko hope may ma advise kayo tungkol dito. thnks a lot.
Kinakargahan lang ba ng refrigerant, umu-okay na ulit? O may iba pa silang ginagawa? I assume na i-convert na iyan sa R34A, right? Original kasi niyan R12...
There must be a leak in your A/C system, bro. Have it checked thoroughly.
7707:band:
Hi Sir CVT, di pa naiconvert R12 p rin medyo madami na rin napalitan like compressor, condenser saka yung mga hose na check rin and yung evaporatorok naman daw. I wander after repair ok naman sya then after 1 day lang pag ginagamit ko na bigla nawawala uli ang lamig. Siguro kailangan pa check ko sa iba mekaniko na lang kaya lang medyo nanghihinayang ako kasi malaki na nagastos ko dito. thnks uli sa advise.
Technically bro.,- hindi mo siya maipaparehistro na sa LTO (I think) dahil dapat ay puro R34a na ang ginagamit na refrigerant effective last year(?)..... Anyway, where is your location? Need this information para makapag-recommend kami ng A/C shop to you.... Or, you may want to go to the A/C related discussions/forums here....
7707:band:
ETIAN,i pa check mo yung cooling coil ( parang aluminum box yun. sa may aircon box ) mo. baka kasi original pa yan at di pa napapalitan. sa katagalan nyan kasi, magkakaroon yan ng crack o butas na pwedeng labasan ng freon. yung sa akin nga, sinlaki lang ng butas ng karayom kaya yung aircon ko di nagtatagal until mapalitan nga ng bago. yung ipinalit ko surplus lang. it cost P 3,500. ayos naman ang lamig, talagang malamig!
kung maging problema mo naman yung overheating, ang gawin mo, doblehin mo yung rubber sa loob ng takip ng radiator cap. gupit ka ng interior ng gulong. kasing laki ng rubber sealer sa loob ng radiator cap. ang mahalaga, hindi makasingaw ang init sa takip ng radiator cap mo. Tapos yung isa pa, baka yung radiator fan mo nag pre-free wheeling na. ipaayos mo yun. ipasabay mo sa takbo ng makina ang takbo ng radiator fan mo, mura lang yun. P 450 lang ata, makikita mo, malamig na aircon mo di ka pa mago over heat sa kalsada.
kung gusto mo pa, alisin mo narin yung metal can na nage enclose sa air filter mo para hindi mahirapan yung van mo na humigop ng hangin tsaka palitan mo yung muffler mo ng STRAIGHT.
mga sirs tanong lang po..hirap na po humatak un vannette ko 94 model lalo na sa pataas at kpag nkastop cya naka-on a/c medyo nanginginig na cya..bka po my suggest po kayo..at magaling na mekaniko...pasencia na po bago lang po ako dito...thanks po..
