Page 11 of 14 FirstFirst ... 7891011121314 LastLast
Results 201 to 220 of 264
    Jun 2011
    #201
    Pasali po, last Jan 19 na biyahe namin to N.E.
    Car Model: Nissan Exalta STA 2000
    Route: Pasig - La Torre, Cabanatuan - Pasig
    Gas: Flying V 95ron
    14 Km/L
    OD is always ON
    Mar 2012
    #202
    2011 X-Trail. 5.5 Km/L to date.
    Nov 2014
    #203
    please visit our web site for info.
    zeecarplus.net
    call us
    724-8309
    726-9116
    #204
    93 vanette local Z20 engine (2.0L)
    10km/l
    ac on
    40psi tire pressure
    fuel - red colored gasoline (premium)
    9pax+cargo.
    route: city and province.
    Jan 2014
    #205
    Nissan Sentra 1.5cc 97' model M/T
    11.5km ~ 13km/liter fuel consumption
    mixed city and SLEX driving, fully airconditioned
    Premium Gas ( xcs petron or gold caltex)
    Feb 2015
    #206
    Quote Originally Posted by valskie01 View Post
    ride: nissan sentra
    Year:2006
    Displacement: 1.6L
    Engine Configuration: inline 4
    Fuel Consumption:
    -City: 7-8 km/l
    -Highway:14 km/l
    -Mixed: Optional 10-11km/
    I'm planning to get this as well now, how's its maintenance? I think I can spare enough cash for fuel nowadays, so I just need to consider the maintenance cost
    Mar 2015
    #207
    Nissan sylphy m/t 4,000 odo reading city-12.4kms/ltr. hiway-14.6kms/ltr. full tank to full tank manual computation.
    Jun 2010
    #208
    Nissan urvan escapade e24 series 2008 model. After ma top overhaul, 5+ kms per liter ang naging consumo unlike before kaya mag 9+ kms/ltr. Taguig - Baguio - Taguig route. Aircon on all the time.
    Jun 2015
    #209
    Maganda ba fuel consumption ng nissan sentra?
    Aug 2014
    #210
    Nv350 mayron na po new release? Any feedback sa FC ng new urvan nv350?
    Mar 2012
    #211
    99 sentra b14 stock GA16DNE
    gasoline------------sea oil 97
    terrain--------------cement/asphalt road
    ave speed----------35-40kph (mtraffic kasi dami enforcer d:-)
    ave travel----------20km/day
    tire size------------15 (rota) w/ 195 55 15 tires)
    tire pressure-------33psi (apat na gulong)
    pa puntang office mga 10km lang aabutin nang 45mins dahil sa traffic, spent 20-30mins slow moving traffic bumper to bumper, dadaan pa ako nang school, daming tricycle sa kalsadang humihinto kung saan2x kahit sa gitna nang daan...
    ng pa gaas ako nung umilaw fuel indicator, (php500 or 12liters), umilaw ulit ang fuel indicator sa panel gauge after reaching 118kilomters (118km/12l) so nasa mga 1:9.8 km/l yung gas consumption ko, not bad
    Jun 2015
    #212
    Samin mula makati to isabela around 482km nibyahe namin...almost 1 full tank...grand livina 2011 manual yung sa amin
    #213
    Mga boss tanung ko lang may bago ako nabili nissan sentra gx 2010 43k pa mileage. Anu po fuel consumption nito na series 2010? City and highway and anu po rpm ko dapat mag shift gear salamat mga boss
    Mar 2015
    #214
    Quote Originally Posted by meldred0519 View Post
    Shifting at 2,000 to 2,200rpm is just right for me.
    #215
    If 2k rpm po ilan naabot ng 1liter na gas? And anu po mainam yung preium or unleaded?
    Aug 2015
    #216
    My wife daily use of our nissan sentra 1.5cc is roughly 9 - 10L/km fully airconditioned and she's using petron premium gas. Not bad for a 1.5cc engine city driving (south)
    Mar 2015
    #217
    Sir you have to try it for yourself po. It all depends on how light footed are you in driving your car. Generally at 9 to 10kms/ltr. is a good average for city driving. Usually a 1.3 to 1.6 liter engine consumes within this range give and take 1km. Will depend on your driving habit. I use premium gas as i prefer more power for overtaking when needed.
    We have an old sentra B13 1.6 engine and it does 8.5 to 10kms/ltr. On hiways drinks 12 to 14kms/ltr. And there was a time that it gave me 16kms/ltr. After changing the oil and had it tuned up. It runs great and very cheap to maintain.
    #218
    Salamat how about sa takbo po? Normal po ba yung mai Parang mai ingay pag dumaan sa medyo lubak2 na espalto. Like parAng bearing ba. Pina check ko ang bushing ok man ang bearing hub ba yun hindi pa. Or talagang normal lang yung ingay na yun?
    #219
    hindi dapat maingay yan sa pagdaan sa lubak.
    have the entire suspension system looked over, po. ball joints, rack ends (outer and inner! the inners tend to be forgotten because they are hidden).. tie rod ends.. shocks including shock tower ends.. rubber bushings! when the rubber loosens, there may be squeeks, or the metal parts may hit each other.. and bearings, just in case..
    also, the exhaust tube running under the car's floor might also cause some noise, if it is loose.
    crawl under the car or have it lifted in the gas station, and look for loose fittings underneath.
    and don't forget to inspect the rears, too. they also make noise when worn..
    good luck.
    Mar 2015
    #220
    When doin hiway runs sir i usually cruise around 80 to 90kph sir or 2,700 to 3,000 rpm.Unusual noises po is not normal. Have your car check again sir kahit po sa casa or any under chassis specialist. Pag bearing po usually d po ito titigil sa ingay kahit smooth yun daan maingay pa din.
Nissan Fuel Consumption Database
