Results 1 to 9 of 9
May 31st, 2008 10:46 PM #1
Help po. We have a Mitsubishi L200(Endeavor) model 2000, bought it second hand 3 months ago. First time I drove it just last week and noticed that the temperature rises when the car is idle(not running). The AC is switched on as well. When the car runs, the temperature slowly coming down. Any idea about this?
Thanks.
May 31st, 2008 11:00 PM #3
June 1st, 2008 01:45 AM #4
June 1st, 2008 03:06 AM #5
Tsikot Member Rank 4
- Jan 2007
- 2,326
June 1st, 2008 03:39 AM #6I agree that the fan and cooling system blickage are the most likely suspects. Easy to check the fan kasi just listen/look for the aux fan to activate habang tumataas yung temp.
Kung tubig naman ang laman nung radiator at nagbara na, you can go for a radiator overhaul and flush then replace na with coolant.
June 1st, 2008 11:40 AM #7
Maraming salamat po. Just checked the radiator and drain all the water then replaced with coolant. May mga kunting rust na din on some areas. But the temperature is coming to normal now...
Again, thanks po sa inyo.
June 1st, 2008 01:17 PM #8
June 1st, 2008 07:11 PM #9
Xiaomi E-Car
