Results 1 to 9 of 9
- Dec 2009
- 18
July 23rd, 2014 09:40 PM #1Hello bros. kotse ko lancer 97 glx (automatic transmission power everything). papasok na ako sa trabaho tonight paatras ng driveway napansin ko hirap mag atras yung right rear wheel. may malakas na tunog as if may humaharang. nakaatras naman ako from driveway to street pero when i put it in drive 'D' ayaw na umandar yung gulong. pinarada ko na lang kasi baka maging worse lang ang problem. ano kaya ang problem and possible solution na dapat kong gawin sa nag lock up na gulong? thanks!
July 23rd, 2014 09:50 PM #2
Nilusong mo ba sa tubig tas nakahandbrake nang pinarada?
Sent from my 3310 using Tsikot Forums🙈🙉🙊💀💩
July 23rd, 2014 11:08 PM #3
Two things:
Rear brakes lock
Wheel bearing needs replacing.
My guess... Wheel bearing.
- Dec 2009
- 18
July 23rd, 2014 11:40 PM #4salamat sa replies. never nadaan sa baha yung kotse. although napansin ko since non stop ang ulan recently basa yung loob. pa check ko sa mechanic bukas. sana matuyo na ang loob by then.
- Jun 2004
- 1,311
July 24th, 2014 12:56 AM #5Stuck parking brake? remove the wheel, get a hammer and try to tap it loose...
Happened on our old car before. But again this probably won't be the recommended fix.
- Dec 2009
- 18
- Oct 2006
- 5,697
July 24th, 2014 02:37 PM #8
Had these problem with my previous car,
had to remove the wheels and struck the drum with a hammer to let loose,
i am using a cheap replacement brake shoes back then, after the that incident,
i replaced it with an OEM brake shoe, never happened again.
- Dec 2009
- 18
July 24th, 2014 09:14 PM #9
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
