Montero Sport ride height problen
The rear right side of my MS is higher than the left. does anybody try to correct and solve this problem because according to mitsu SA, nothing they can do about this in MS because the cause is the fuel tank location is on the left side of the car that affect the ride height. But even the fuel is near empty still left side is lower than the right.
Re: Montero Sport ride height problen
Its kind of a normal thing. Some people just get really o.c. about it. Even with the tank empty, its still a heavy chunk of metal.
Grab some poly spring spacers from your local Old Man Emu or Ironman dealer. They sell them starting at 10mm. They are usually used to level out the difference between front ride height and rear ride height but you can also use them to level side to side differences. Try some on the left front spring just to see.
Quote:
Originally Posted by
perrydel
Ganito rin yung dati kong ride, Isuzu Crosswind, pero sa left side naman ang mataas kasi nasa right side ang fuel tank, and it was corrected by adjusting the torsion bars.:)
yan talaga hirap sa mga matatangkad na ladder frame na suv eh like the this and Fortuner, madali mahalata kung di pantay. kaya mas okey talaga ang crossover
OTEP
thanks OTEP, its a good idea i will try this.
Hindi... okay ang fotuner, pantay talaga sya...
Mac40
wala torsion bar MS, mas madali kung meron
Kung may sakay ka... sa kanan mo pa-upuin, baka nasanay lang yung montero mo na mabigat sa kaliwa palagi.
zix888
nasubukan mo i-drive ng may passenger ( balanced), tapos after parking, tsaka mo icheck ang height.
yes, equally weight distribution naman, kahit load lahat nasa right side kasama din bumababa left side. tingnan mo mga MS halos lahat mababa left side, lalo na mga 4X2.
kaya pala parang mas malambot yung tire ko sa rear left side parati
Problema din pala ito ng MS akala ko Strada lang...
lahat ba ba ms ganyan to kasi laruan ko dito ok man sya pantay man 2012 model
TS, have you resolved this issue?
this is also my problem. i would like to ask if it is possible to swap springs Left to Right so that mag even out sila in time?
can O-sulee or other spring cushions help?
ek2jayvee
Not yet, but I will try to swap the front shock and spring in my next pms, I think it is possible.
I did not try putting spring cushion yet.
