For sharing..
Just had my 1k PMS done for 2015 GLSV at diamond motors greenhills.. Total damage Php 5,359.72 [emoji4]
Also had my navi checked because of distorted maps, Kuya Edison said that the SD card issued to me (with black dot at the back of the card) was for 2014.. 2015 montys should have the green dot at the back for it to be compatible..
Mga sir, di ba ma void ang warranty if magdala ako ng sariling oil filter for 1k km pms? If pwede anong brand kaya ang ok?
Mga sir 20k kms na po c monty ko.hingi sana ako idea for a good quality of oil for OC?ilang bottle kaya sir bilhin ko.thanks...
if you try to read back or check the thread on synthetic and fully synthetic oil, bypass filtration, you will see a lot about discussions on oils and filters. some of the oils used by fellow montero owners are top 1 sdo, delo 400, royal purple, zic, mobil tdt/delvac, motul crdi...etc. aftermarket oil filters are baldwin, fleetguard and some others i can't reckoned.
asking for good quality oil is subjective. the casa oil (turbo xp) itself is a good quality oil if not then hindi recommended ng casa. although, we try to find an alternative aftermarket oil kasi may mas maganda pang specs at mas mura o etheir mas mahal. try to experiment, if you are not bothered with the type of oil that casa supplied then stick to it. if you want a less or more expensive type of oil then go for it.
