Page 38 of 162 FirstFirst ... 283435363738394041424888138 ... LastLast
Results 741 to 760 of 3240
    Apr 2012
    #741
    comparison b/n baldwin fuel filter BF7534 to GTV 2012 fuel filter element.
    GTV 2012 fuel filter built-in casing
    BF7534 fuel filters...i have 4 of these i cannot use in my GTV. whoever interested PM me...
    May 2007
    #742
    BD28 is an oil filter. BF7534 is a fuel filter.
    Ay onga, thanks for the correction. ;)
    Jun 2012
    #743
    pag nagdala po ba ng sariling oil, void agad ang warranty? lahat ng tinawagan kong dealer ganun ang sinasabi e. baka may mga kakilala po kayo dyan na hindi ma-void. pa pm naman po sakin. thanks
    May 2007
    #744
    Not sure kung void pero noted sa warranty booklet na sariling oil ginamit during the PMS.
    Try mo sa mga Diamond Motors.
    Jun 2010
    #745
    1,000kms PMS 2013 GLX MT Non-VGT, Mitsubishi Alabang ( Westgate), satisfied customer, friendly SA (Sir Cho), they explain what particular job they will do, ask you to choose mineral or syn - no pressure to use syn oil, with some advises to keep your monty in top shape...but they didn't have a free carwash after or they just forgot...overall satisfied (Php 5,3xx syn oil and others), hope they'll always be honest on their service....keep it up!
    #746
    Please PM code to me too. I'm about to get my 5000km PMS. Thanks.
    Feb 2013
    #747
    Change my SCV after 35k on odo, bought it from casa through the mechanic its 10taw, kung idaan sa casa 15taw but he gave me only 1 mnth warranty, dont know if i did right
    Feb 2013
    #748
    Any feedback with Citimotors Alabang? Due for 1K PMS na kasi ang aming Monty. Thanks!
    Mar 2012
    #749
    Quote Originally Posted by ricciboy View Post
    sana sir hindi katay yung nabigay sayo. friendly reminder lang
    Jan 2013
    #750
    Quote Originally Posted by jasperjugan View Post
    Sir sakin na lang yung SCV mong pinagpalitan? Nasa iyo pa ba? Bayaran kong 500. I want to study it. Yung SCV ng D4D NG INNOVA we already found a way kung pano ayusin pag nag stick na sya at d na nag function ng maayos. Kung same ang design ng SCv ng DiD mas makakatipid tayo kesa palitan agad. Yung Scv ng d4D ayaw ng mag function properly dahil sa water contamination at bad fuel nag stick at ayaw na umandar ng hi lux. After the mod/ repair to the scv good as new na.
    Jan 2013
    #751
    Sir try using 2T to preserve or lengthen the life of fuel system parts ng 4D56 engine. But pinaka importante is fuel up sa kilala o suking gas station. Fuel contamination kasi number 1 cause ng pagkasira nyan. Out of warranty na ba yan sir? 35k pa lang dapat free pa replacement ng scv kung nasira if under 3 years old sya. Search nyo dito sa tsikot forums 2T diesel engine to get more info
    Feb 2013
    #752
    Quote Originally Posted by zix888 View Post
    2008-2011 will have no problem with 7535
    2012- present uses the filter element that has a built-in casing and 7535 wont be fit
    sir zix, ano bale filter puede for GLS-V 2012 model? TIA.
    Feb 2013
    #753
    Quote Originally Posted by babynos01 View Post
    Haha, i wasnt able to clean it pa, kasi i cant remove the bolts by hand.
    I'll go instead to my suking gas station to have it removed and cleaned by soap and water. They have an hydraulic wrench there.
    EGR assembly ng montero nasa 7k ata.
    pasensya na mga sir...cant relate much, what is EGR btw? gls-v '12 mine and planning for my 5k PMS..tnx
    Feb 2013
    #754
    Quote Originally Posted by keal01 View Post
    5.3k ung sa akin. Same oem oil filter + synthetic oil (turbo xp oil) *DM ValleVerde.
    san po sir ung DM Valle Verde? can i have the contact no? due for 5k PMS sa gls-v ko.tia
    Jan 2013
    #755
    Quote Originally Posted by marino View Post
    Exhaust gas recirculation valve. I suggest you just let the casa take care of that during PMS iy you are not mechanically inclined. Alam naman nila sched nun. 15K PMS yata. Ako I cleaned my Egr valve at 10k OCI . Medyo makapal na soot kasi wala naman nagbebenta ng euro 4 diesel sa probinsya na malapit sa amin.A good socket wrench with a 12 and 14 bit is used. Ginamitan ko rin ng bench vice nung tangal na sya para tangalin yung valve sa piping nya.
    Jan 2013
    #756
    2012 glx m/t yung s amin acquired June 2012, ganyan din yung fuel filter. Do you just replace the filter element. Meron bang after market equivalent ito?
    Feb 2013
    #757
    good day sir's..advisable ba to have engine wash sa monty natin? ive noticed kc na marumi na engine ng gls-v ko..any advice? tia
    Feb 2013
    #758
    Quote Originally Posted by Ammiel Barlis View Post
    many thanks sir sa info...
    Jan 2013
    #759
    Did some research and good news for all 2012 and above Monty owners, I found out that the fuel filter/pump assembly being used in our ride is similar to hilux , and i guess its also same for Innova and fortuner cause it uses the same engine. You just need to replace the fuel filter element inside the filter housing. Kung bibili kayo outside Casa sa mga auto supply ng fuel filter just ask them for fuel filter ng hilux,(1kd,2kd engine).
    *monty_GTV thanks a lot for the pics you posted. It helped a lot sa paghahanap ko. Toyota part number for fuel filter element is 23390OL041 (23390-OL041). Instructions on how to clean fuel filter assembly and replace filter element:
    How to: Change the Fuel Filter in a Toyota Hilux (2005, up) • trinituner.com
    eto video naman kung mas gusto nyo panoorin:
    How to change the fuel filter on Toyota Hilux Mk6 Vigo - YouTube
    location of the fuel filter in the monty is driver side inside engine bay above the wheel the beside the brake masters. Maganda pala yung filter element na ito kasi activated carbon ang gamit kaya inupgrade ng MITSU.
    Jan 2013
    #760
    it's no surprise for mitsubishi to use toyota parts. Parepareho lang kasi parts supplier ng toyota at mitsubishi thailand. Yung Power side mirror switch nga sa monty natin Toyota made . I saw it nung magbaklas ako ng dash cover to install some switches.
Montero Sport PMS Thread
