basta casa ng mitsubishi, synthetic talaga sasabihin sayo na ilagay kahit luma man o bago mitsu mo dahil may sarili silang oil. yang sinasabi nila na fully synthetic na ilagay mo is their own brand.
Bros,
Had my monty's 1,000 km check up at Citimotors Makati last Thursday, Mar. 12, 2009. The following is the breakdown of the cost I paid for:
10 liters fully synthetic oil 5,600.00 Oil filter 780.64 Engine flush 333.00 Shop consumables 234.19 Gasket, oil drain 35.84 Discount (81.63)Total 6,902.04
FYI.
Bros,
10 liters fully synthetic oil P5,600.00
Oil filter 780.64
Engine flush 333.00
Discount (81.63)
Total P6,902.04
FYI.
1t PMS on my GLS cost P7,241.36 less P500 discount, P6,741.36 net. had it at union motors paco. the SA advised to do flushing which cost about P548 (not sure of exact amount). there were no shop consumables and the like charged to me, just some rags which wasnt really much.
re engine oil, the SA strongly adviced to use fully synthtic as this was the advice of the mitsu plant. initially, i planned on using regular oil and just use fully syn at 10kms pms. but i didnt argue anymore and acceeded thinking he might void the engine warranty if i insisted on the reg oil...kasi nga fully syn ang dapat gamitin ayon sa planta. he also mentioned that there was a customer before who insisted on using reg oil on his monty and eventually noticed that humina ang hatak nung makina. the engine oil used was motul H-tech 100 plus, 5w-30 fully synthetic.
days after, i searched on the motul website and found out that this particualr oil is for gasoline engines!!! so i called union's service to inquire re this and according to the warranty department, this particualr oil can be used for both gas or diesel engines.
after more than a week post the 1kms pms, i didnt notice any problems naman sa monty ko. in fact, parang medyo lumakas ang hatak.
*studebaker :: sir ang mura naman yun monty ko 1k pms nya sa citimotors umabot ng 7,5k 10 liters din bakit ganun?
Had mine serviced at Union Motors Otis:
Perform 1,000 kms check-up: 407(free)
Cleaning materials: 150
Filter Oil: 1643.24
H-Tech 100 Plus 9 * 560 per liter = 5040
Engine Flush 3 * 173 = 519
Colored Rags 3 * 2.04 = 6.12
Total: 7358.36 less 500(discount) = 6,858.36 pesos
Overall service is good, only complain is that it did take us 3 hrs to finish, we're just the 20+ in the queue that day, while in toyota we only need about 2 hrs and were like the 60th. I think they need to hire more employees as MS would be a sure hit in foreseeable months.
Sir stubby, pansin ko nga mababa ang presyo ng filter na charged sa akin although comparable sya sa price ng Carworld na around P800 as mentioned by djin_xxx
sir pahehengs, umabot ng P7,500 sayo? may P600 difference tayo ah. Please check yung cost ng oil filter mo baka dun nagkatalo. P780 lang kasi charge ng Citimotors sa akin for the filter.
Thanks!
Hi, just want to share my 1k and 5k PMS at Diamond Fairview
1K PMS
Labor 356.25
Parts:
w/shld cleaner 133.93
oil filter 1,704.00
F/synthetic oil (8L) 4,000.00
Total Parts 5,837.93
Other Materials 341.56
Total + VAT 7,320.03
Less: Discount (399.00)
Grand Total 6,921.03
5K PMS
Labor 401.79
Parts:
oil filter 1,704.00
f/synthetic oil (1L) 500.00
Total Parts 2,337.93
Other Materials 341.96Total + VAT 3,451.48
Grand Total 3,001.48
So far I have no complaints on service. For my 1k PMS, it took halfday so I have to come back for my MS. For the 5k PMS, it only took 1hr. Hope this helps as a reference for those having their PMS.
studebaker ::: cge sir ma check nga, btw, sa mga ms owners, invited tayo ng strada club sa eb nila come and join hehe![]()
I called different Casas to inquire about their prices for 1000kms check up and they do give different quotations particularly on oil filter prices (1.9K - 2.2k) though their Turbo XP FS are firmed at 560/li and 9 liters needed.
Union Motor Corp. Kalookan (DCM Holdings, Corp.) gave me the most competitive one. I tried to insist to use mineral oil. pwede daw but they will note it sa service booklet and once problem arises on the engine di na covered ng warranty. in short void if i will use non fully synthetic oil. but they gave me a choice since marami daw namamahalan sa Turbo XP and they allow me to choose between:
Veredium Fully Synthetic 15W-40 (450/li) or Turbo XP 15W-50 (560/li)
8 liters compared to 9 liters from other Casa.
oil filter: P928 (i asked if replacement original daw)
yun lang daw i asked 2 service advisors again kung 8 liters ba or 9 liters and Allan Soleta and Jeff confirmed that only 8 liters are needed. ayos! wala rin daw flushing dapat.
so guys if you want you can try this casa. going 900 kms pa lang ako but definitely i'll go to them on my 1000 kms PMS![]()
is it necessary to use fully synthetic oil for montero? nasa users manual ba ng montero to use fully synthetic or just follow the recommended oil viscosity and api/acea rating?. diba pag diesel every 5000km ang change oil.
IMO mukhang mataas ang cost ng pms ng montero compare to other SUV.
450/liter x 8 = 3,600 oil palang ito. tapos every 5000km pa
but kung every 10,000km ang recommended change oil interval ng montero ok na ang fully synthetic.
hi sir..we had the same concern before with the strada thread and basically our club contacted mmpc to get the answer. mmpc suggest/recommend to use fully synthetic oil for either engines for the strada and same goes with Montero sport. your warranty will not be void if you opt to use just the regular oil (as long as same viscosity/rating as per manual). if you do use fully synthetic oil, it will be good for at least 10,000 km before changing the oil again. however, you would still need to have your regular pms every 5,000 km but only change the oil filter and top up if needed and of course the other regular adjustments and check during that interval.
service advisors are trained to always give you different things...remember they work for dealers and not mmpc. you can actually test your service advisors if they really know their stuff...ask them parts of your car (for example..where is the turbo intercooler), you can actually see if they really know the cars they are servicing.
if fully synthetic oil is used, the 10,000 kms interval will be followed. only the oil filter will be replaced at 5,000 kms. may order daw ang planta na fully synthetic lang for MS so like other MS owners who already had their PMS i'll go for synthetic na rin para less hassle. sayang ang warranty for 3 years/100,000 kms![]()
hi sir...thats the same thing SA said to us...but unless they can show that letter that says this "order" than we can say we believe them. but then again sir...if kaya bumili ng more than P1M na car, kayang kaya mag fully synthetic. ako nga 2.5 liter lang strada.but i choose to use fully synthetic vs regular oil. if you want to take care of your auto...kaya naman spend the right accessories/maintenance for it.. btw, if 4m41 engine..i think dapat fully synthetic..again.. i think...IMO.![]()
Guys...here is an email from MMPC on fully synthetic oil. I hope this helps..if you need proof.i have the original email.
"Dear -----,
Good afternoon. It's nice to receive mail from you once more. Regarding your inquiry. There is no cause for worries about this issue. To give clarification in all of this, we are recommending the use of fully synthetic oil for all Mitsubishi turbo-charged engines because of its tremendous benefits especially in relation to its viscosity and carbon deposits reduction more importantly, if the vehicle is still within the warranty period. However, we are not mandating this, if our customers really wanted to use other oil they can do so provided the oil conforms to the required viscosity and API ratings ( CD or higher ).
With regard to its oil change interval, ALL DI-D (Direct Injection - Diesel) Engines must change their oil every 10,000 km. when using the Mitsubishi Turbo-XP Fully synthetic oil and every 5,000 km. when using Mitsubishi oil or any other oil than the aforementioned.
I hope that the above explanation has shed light to your concerns.
Sincerely,
Noted by: D.M.Doctor"
here is an attachment they sent to me regarding synthetic vs reg oil.
SYNTHETIC VS. MINERAL/PETROLEUM LUBRICANTS
Synthetic Oil – is made by combining lower-molecular weight materials to produce a finish product with planned and predictable properties. These are custom designed products in which each phase of their molecular construction is programmed to produce what may be called “the ideal lubricant”.
Mineral Oil – have physical components, both desirable and undesirable which are inherited from the crude oil from which they are refined. Crude oil possesses thousands of varieties of contaminants depending upon the oil’s geographical and geological origins which no amount of refining could remove.
Corrosive acids, paraffins and other waxes, heavy metals, asphalt, napthenes and benzenes, as well as countless compounds of sulfur, chlorine and nitrogen remain in the finished product.
1. Low-temperature fluidity (flowability)
Contaminates present in petroleum oil which contribute to low temperature thickening are entirely absent in synthetics. Synthetics’ fluidity is still stable to as low as – 65F.
Petroleum oils have an inherent percentage of paraffin crystals that enlarge and causes oil top congeal at low temperature. This results to hard starting.
2. High-temperature thermal stability
Since piston rings and cylinder walls could reach up to 500F temperature during operation, petroleum oil and additives decompose and shortens service life, while synthetics are not affected.
High-temp thermal stability permits an engine oil to deliver overall extended life (significantly longer drain intervals) in all driving conditions, because it prevents the phenomenon of sludge and carbon deposit formations on critical engine parts (valves, valve guides, oil channels, filter assemblies, piston rings, etal.)
High temperature stability, as well as oxidation-resistance, is of absolutely paramount importance when it comes to turbocharged engines. Because it must both lubricate and cool the turbo unit, the oil must be specifically formulated to withstand the turbo’s extremely high operating temperature. Oil film temperatures often exceed 450F in the turbo unit during operation, and can surpass 650F.
In order to qualify for the American Petroleum Institute’s top “SF” rating, a motor oil must pass the III-D test. This means that it can thicken to no more than 375% of original viscosity at the end of 64 hours of continuous running.
3. Film Strength
This refers to the amount of pressure required to force out a film of oil from between two pieces of flat metal. The higher the film strength, the more protection is provided to moving parts.
Synthetics routinely exhibit a nominal film strength of well over 3,000 psi, while petroleum oils average somewhat less than 500 psi.
4. Viscosity
The property of a fluid that tends to prevent from flowing when subjected to an applied force. Highly viscous fluid resists flow; while fluids with low viscosity flows easily.
If the oil easily flows, the engine will turn freely and the lesser fuel it will require to accomplish a given amount of work. The lower the viscosity, the better the fuel economy of the engine.
Synthetic oils are created with low viscosity without incurring the excessive oil consumption (due to evaporation). It is evident that low-viscosity oils will help minimize engine friction which results to better fuel economy.
Lower-viscosity synthetic oil is formulated to resist evaporation and provide high film strength, this lighter oil will actually deliver more complete protection to engine parts since its more rapid circulation delivers both better lubrication and cooling characteristics.
