Results 10,661 to 10,670 of 14348
July 25th, 2014 09:27 AM #10661
I had my power steering oil sending unit changed. It sprung a small leak which I didn't really notice. Luckily, a friend looked under my hood and pointed it out to me.
July 25th, 2014 09:29 AM #10662
July 25th, 2014 10:05 AM #10663
*Nelany: 100k odo. Yung filter linis lang pwede pa naman kasi sayang daw sabi ng trusted mechanic ko. Oil used Shell spirax yung Black yung bote 300+ pesos ang isa. Result is ganda ng shifting halos di mo ramdam.
- Dec 2009
- 54
July 25th, 2014 10:23 AM #10664*all Sir paano kaya ayusin yun roller ng 2ndrow seat ng pajero jdm? Ayaw kase mag slide paharap nag stuck though naiaangat naman namin yun seat. Thanks!
Posted via Tsikot Mobile App
July 25th, 2014 10:47 AM #10665
- Mar 2014
- 48
July 25th, 2014 12:56 PM #10666Sir ilan liters of ATF sa change ATF nyo?
may nabibili ba gasket para sa oil pan or sealant/3bond lng?
tnx
July 25th, 2014 01:00 PM #10667
Wag ka gagamit ng 3bond sa oil pan, masyado matagal yan bago mag set kaya mag leak. Just use silicone sealant ... nagamit ko yata was 12ltrs pero full bleed un kasama atf cooler
July 25th, 2014 02:04 PM #10668
Ganyan din maintenance ko sa A/T... every 40k palit filter.
ang sabi naman ng mechanic ko, lumalaki raw kasi butas nung strainer/filter ( due to wear and tear) kaya maganda rin na palitan na... and tsaka nakababa na pan might as well replace it with a new one.
Mobil 220 gamit ko... I think hindi naman maselan ang A/T natin as long as tama ang specs ng fluid na ginamit
July 25th, 2014 02:33 PM #10669
A friend recently had his a/t pan pulled down and it consumed around 6-6.5 liters of ATF... mas marami nagagamit ATF kapag dialysis style or bleeding.
AFAIK, wala talaga gasket ang pan ng A/T... ang meron gasket yung filter/strainer
Although may nabibili gasket (for the pan) sa ATCO Pasay pero hindi OEM (parang gawa sa cork na manipis)
July 25th, 2014 02:40 PM #10670
Wala parin spare tyre?
2025 Nissan Kicks
