Page 37 of 37 FirstFirst ... 273334353637
Results 721 to 739 of 739
    Dec 2017
    #721
    Heater relay if i'm not mistaken.
    Your intake hose is begging for replacement, dami butas at yung puno sagad na sa clamp.
    yes sir pinalitan na po yan. nasan po ang 2nd fusebox ng L300?
    #722
    The old school diesels only has 1 fuse box underneath the steering column opposite the column shifter. This is the same as the 190s 4D56 L200 Estrada.
    Dec 2017
    #723
    ahh ok sir thanks. wala po kasi sign of life ang blower at all speeds. wala naman sa fuse box ng fuse for blower. resistor o relay na po ang problem nito?
    #724
    Naka hiwalay nga yata ang AC accessory sa L300, just trace back the wire from magnetic clutch then a separate relay then going into the cabin. You could also check the rotary knob of AC, the blower resistor is usually mounted near there or at the body of blower housing. L300 is one of the worst to work as the tight and dirtiest space, you should extend some patience in troubleshooting.
    Dec 2017
    #725
    ok sir thank you po. any tips po for removing the dash?
    #726
    IIRC there are 4 screws holding the front control panel, you have to open the glovebox. The fan blower is just below the passenger side dash pwede mona kapain siguro kung kaya.
    Dec 2017
    #727
    thank you po.
    Dec 2017
    #728
    good am po. pwede pasend kung ano itsura ng blower resistor ng L300?
    nasa process po ako ng pag disassemble ng dash
    Dec 2017
    #729
    mali ang results sa google pag sine search ko po itong part na to? any info kung ano po ito? ty
    May 2019
    #730
    Quote Originally Posted by christian p View Post
    hi meron po ba pics ng resistor ng blower ?
    Dec 2017
    #731
    Quote Originally Posted by kdens View Post
    wala sir
    May 2019
    #732
    wala sir
    ok po, saan kaya nakalagay yun ?
    Jan 2008
    #733
    Naka kabit sa blower housing.. right after ng blower before mag cooling coil.. usually may 4 wires yun at yung resistor naka pasok sa housing para malamigan
    May 2019
    #734
    Quote Originally Posted by shelu View Post
    there must be something wrong in your cooling system. check your radiator, baka barado., change coolant and check the temp sender. yup, baka barado na rin ang thermostat. panahon na para palitan. wag mong tanggalin ang thermostat gaya ng ginagawa ng karamihan. it will do more harm than good.
    hi, meron ako nabili third hand na L300VV(1997 model), mga one year ago na , bihira gamitin pero lagi nauubos yun tubig sa radiator(filtered water yun nilalagay ko,di pa nasubukan lagyan ng coolant ),meron kaya thermostat yun L300 ko ?
    #735
    Before you plan on putting in a coolant, better look for the cause of the water loss. Sayang kasi kung lalagyan nyo kaagad ng coolant kung mauubos din lang. Madaming cause ng coolant loss, syempre kung may visible leaks, then baka barado radiator, stuck up thermostat valve, or defective cylinder head gasket. Better have it checked by a competent mechanic para ma pin point yung problema.
    May 2019
    #736
    Quote Originally Posted by jvnj View Post
    ok sir, pero wala ako makita leak sa radiator or hose and not sure kung merong thermostat, btw kelangan ba palitan un radiator cap ?
    Dec 2017
    #737
    good pm, oil bath type ba ang air filter ng L3? ty
    Jan 2020
    #738
    Quote Originally Posted by johnart View Post
    mine is 17 years na. aircon busted, body rusting but engine is still strong 2.0 gas. With the aircon I would suggest that you transfer the front condenser to the bottom of the sliding door and changing the rear aircon to a dual blower ceiling type This may prevent overheating also
    sir, tanong ko lang po fuel consumption ng
    Versa Van gas 2.0? this is one of my option po kasi.,
    thank you po
    Dec 2017
    #739
    Quote Originally Posted by SydneyBristow View Post
    thank you po
    around 8 kmpl sir
Mitsubishi L300 Versa Van
