Results 561 to 570 of 2039
- May 2008
- 289
October 10th, 2010 11:37 AM #561
- May 2008
- 289
October 10th, 2010 11:38 AM #562
October 10th, 2010 12:02 PM #563
May VGT turbo din naman ang 4M4 3.2.
http://en.wikipedia.org/wiki/Mitsubishi_4M4_engine
4M41
Displacement — 3200 cc
Bore — 98.5 mm
Stroke — 105.0 mm
Fuel type — Diesel
Intercooled turbo
Fuel system — Electronic control type distributor type pump (direct injection inside diesel tube) or Common Rail Direct Injection
Compression ratio — 17:1
Power — 121 kW (165 PS) at 4000 rpm
Torque — 351 N·m (259 lb·ft) at 2000-3000 rpm
Applications:
1999-2006 Mitsubishi Pajero
2005-present Mitsubishi Triton / L200 / Strada
2006-present Mitsubishi Pajero
2009-present Mitsubishi Pajero Sport / Montero Sport
Variable geometry intercooled turbo
Compression ratio — 17:1, 16.0:1
Power — 129 kW (175 PS), 147 kW (200 PS) at 3800 rpm
Torque — 382 N·m (282 lb·ft), 441 N·m (325 lb·ft) at 2000 rpm
Applications:
2006-present Mitsubishi PajeroLast edited by Monseratto; October 10th, 2010 at 12:07 PM.
October 10th, 2010 12:13 PM #564
^^the VGT is only for the pajero....
the 4m41 that is installed in the montero and strada does not have the VGT system...
October 10th, 2010 12:25 PM #565
Why not install up to date VGT engines in next year's MS to cure the turbolag? But are we willing to shell out the differnece?
October 10th, 2010 12:45 PM #566
I think MMPC is already planning the launch of the 4d56 with VGT system for the strada and montero early next year....and in relation to that a co member from thailand have already mentioned that there is already a planned launch of that triton variant that has VGT late this year in bangkok and I'm pretty sure it will go the same for the montero...and also to support the information better for the possible launch, another member who has just returned from a trip in europe said that the triton with VGT has already been released over there so it definitely signifies that its nearing the launch on the AsiaPac market....So as usual, we here in asia especially here in our country are always getting the good stuff later than everyone else...
Willing to shell out you ask? maybe both of us may not but I'm pretty sure theres a lot who is more than willing....Last edited by locoroco777; October 10th, 2010 at 12:48 PM.
- May 2008
- 289
October 11th, 2010 02:54 PM #567
October 11th, 2010 03:10 PM #568
No, its not...
yep I think its possible, maybe you need at least 150 to 200k or even a lot more to get it done and your not even sure if its gonna work properly...
to cite an example, Way back I remember , our co member from bangkok (sir dadz) was able to source out a VGT system from a volvo, unfortunately it didn't go well as expected...
but now maybe a VGT system from a pajero BK would probably work with the current 4m41 installed in the strada and monty....the only problem that i'm seeing is the cost and the place where you can source out the Pajero VGT system...
either way if you find the VGT system expensive, you can always settle for the other upgrades which does not require too much cost as the VGT, like the piggyback ECU system or alcohol injection...
- Feb 2005
- 157
October 11th, 2010 03:55 PM #569
- Dec 2007
- 38
October 12th, 2010 12:09 PM #570mga gurus, how much kaya is the additional price if with vgt system na? price on top of the current price ng monty? para mkapag ipon na heheheh or bumili nlng without vgt
does it mean no huge differences between ceramic vs crystalline ?
