Good day tsikoters, meron akong GLS Sport '05 with 13,500km ODO. This week napansin ko na meron irritating sound when shifting to 3rd gear naririnig ko lang ito kapag nakababa ang window, pero kapag naka AC window closed di mo maririnig. It goes like this (1st gear then when i reached 1500rpm shift to 2nd gear, then 1500rpm shift to 3rd gear- during this period kapag nagrelease ka ng clutch dahan dahan kasabay sa timpla ng accelerator pedal meron ako naririnig na ting-ting-ting-ting..... sounds sa makina, kapag sa 2nd gear meron din kaso mas matagal ang irriitating sounds sa 3rd gear pero kapag tumaas na ang rpm ng mga 2k rpm wala na cya. Pero kapag ang pag shift ko is hataw mode like (1st gear 2000 rpm or up then shift to 2nd when i reached 2K rpm shift to 3rd gear timpla ang clutch wala ka naman maririnig. kapag lang 1500rpm ka nagshift chaka ka may maririnig. Meron na po ba naka encounter ng problem na to. To all adventure owner paki try naman po na open window kayo then shift kayo lagi sa 1500rpm kung may irritating sound din kayo na maririnig. Merry Xmas to all of you!!!![]()
Ngayon I don't push it that hard na medyo middle aged na si ride hehe!
so the next day i brought it back for servicing (less than 20km pa lang). my friend also experienced the same aside from the pulling right his car rotor disc was refaced in less than 6 months of use
