Results 1 to 10 of 195
June 5th, 2012 03:49 AM #1
Sir advise nman po kung anong brand maganda ilagay ng FS oil sa 1st 1000km ng mga Monty ntin at Oil filter nrin?TIA
June 5th, 2012 07:44 AM #2
since bago pa yan, di ba sa CASA mo pagagawa? wala kang choice ng brand kundi yung gamit nila, pumapayag ba sila ng magdadala ka ng sarili mo?
June 5th, 2012 08:35 AM #3
It is advisable to change to synthetic at 15,000 to 20,000 km. Mobil 1 TDT, Motul CRDi specific and Royal Purple are good synthetic oils. Some dealers allow you to bring your own oil and parts.
- Jun 2012
- 1
June 5th, 2012 10:15 AM #4Ang Montero Sports tulad ng Strada ay may EGR (Exhaust Gas Recirculation) valve. Kaya dapat gamitin na engine oil ay ung may minimum rating na API CI-4 or ACEA E6 at makikita mo yan sa container pack. Since bago pa ang Montero mo, kadalasan nilalagay ng manufacturer na initial oil fill bago dalhin sa mga casa ay ung mineral lang kasi un ang mas mura. Kaya, during your 1st 1000kms they recommend to change the oil. But this oil (mineral) is not totally drained. Palaging may naiiwan sa makina na mineral oil. So to be safe use mineral oil din at 1st 1000kms, then upgrade to synthetic oil at 5000 kms. Dapat same brand para no issue with oil compatibility. Just make sure din na may API CI-4 or ACEA E6 minimum rating ung preferred oil na bibilin mo.
- May 2012
- 105
June 5th, 2012 04:38 PM #5
June 5th, 2012 05:49 PM #6
June 5th, 2012 09:59 PM #7
It does not have to be the same brand when switching from mineral to fully synthetic oil.
- May 2012
- 372
June 5th, 2012 10:12 PM #8meron din ako nakita Valvoline sa Ace Hardware, SM North Edsa 15w40 parang P1,049.00 yung 4 liters na may API CI-4 or ACEA E6 minimum.
Valvoline.com > Products > Motor Oil > Diesel Motor Oil > Valvoline Premium Blue® Diesel Engine Oil
June 7th, 2012 01:12 AM #9
1. Petron Rev-X All Terrain Fully Synthetic: SAE 5W-40, API CJ-4/SM, ACEA E4/E9-08
2. Petron Rec-X Trekker Mineral: SAE 15W-40, API Service CI-4/SL, ACEA E7
3. Caltex Delo 400 Multigrade: SAE 15W-40, API CI-4+/CI-4, ACEA E7
4. Caltex Delo Gold Ultra: SAE 15W-40, API CI-4, ACEA E7
5. Shell Helix Ultra E Fully Synthetic: SAE 5W-30, API SN/CF, ACEA A3/B3/B4
6. Shell Helix Diesel HX7 Synthetic: SAE 20W-40, API CF, ACEA A3/B3/B4
7. Shell Helix Diesel HX5 Mineral: SAE 15W-40, API CF, ACEA A2/B2
8. Shell Rimula R4 L: SAE 15W-40, API CJ-4/CI-4+/CI-4, ACEA E9/E7 (Available only in 209L drums)
9. Shell Rimula R6 M: SAE 10W-40, API CF, ACEA E7 (Available only in 18 liter pails)
10. Shell Rimula R3 X: SAE 15W-40, API CH-4, ACEA E5
11. Castrol Formula RS Fully Synthetic: SAE 10W-50, API SL/CF, ACEA A3-02, B3-98 Issue 2, B4-02
12. Castrol Magnatec synthetic: SAE 10W-40, API SM/CF, ACEA A3/B3
13. Castrol GTX Diesel Mineral: SAE 15W-40, API CH-4
14. Castrol CRB Turbo: SAE 20W-40, API CF-4
15. Mitsubishi Turbo XP Fully Synthetic: SAE 15W-40, API SL/CF
16. Mitsubishi Genuine Mineral Oil: SAE 15W-40, API SL/CFLast edited by roydok; June 7th, 2012 at 02:11 AM.
June 7th, 2012 02:34 AM #10
17. Mobil Delvac 1 Fully Synthetic: SAE 5W-40, API CJ-4/CI-4 PLUS/CI-4/CH-4/SM/SL, ACEA E7, E9
18. Mobil Delvac MX Mineral: SAE 15W-40, API CI-4, ACEA E7
19. SEAOIL MAKO Fully Synthetic: SAE 5W-40
20. SEAOIL DEO Max Mineral: SAE 15W-40, API CI-4/CH-4/CG-4/CF/SL, ACEA A3/B4/E3/E7
21. PTT Dynamic synthetic: SAE 5W-40, API CI-4/SL
22. MAG 1 Fleet Mineral: SAE 15W-40, API CJ-4/SM (ACE Hardware)
23. TOP 1 EVOLUTION Fully Synthetic: SAE 5W-40, API CJ-4 /CI-4+/CI-4, ACEA E7
24. TOP 1 HD PLUS synthetic: SAE 10W-30, API CI-4+/CI-4, ACEA E3/B3/E2
25. TOP 1 HD synthetic: SAE 15W-40, API CI-4Last edited by roydok; June 7th, 2012 at 03:04 AM.
Range is not range kasi depending on terrain and driving style. My friend recently took his Audi...
Hybrids and EV
