Results 21 to 27 of 27
April 16th, 2012 05:13 PM #21
Sir ADARTSE our fieldmaster had the same problem last month.knocking sound,loss of power and mausok.had it calibrated at jobstarr calibration in sucat.ok na sya ngayn 9,5k damage.btw it only clocks 35k on the odometer
February 6th, 2016 11:05 AM #22
having the same problema now.. ano po yung butterfly turbo and pako sa egr? hehe sorry di ko naintindihan..
- May 2016
- 2
May 5th, 2016 11:52 PM #23mga sir ganyan din problema ng pajero ko, knocking sound pag nag rerebolusyon, lalo na pag bagong start ang engine at medyo malamig pa. na pa calibrate ko na injection pump ko at inabot ng almost 10k kasi may pinalitan s loob. ok naman sya nawala yung knocking sound, pero after a week bumalik ulit yung ingay nya. ano po best solution dito. salamat po.
- Jul 2008
- 398
May 10th, 2016 10:53 PM #24I have experienced weired sounds also. Sometimes the horn got loose due to vibrations. Another time, the crankshaft pulley separated. It caused the alternator to work in the wrong voltage. Luckily, I serviced it immediately before the pulley fully disintegrated. Things like these do happen in a 17 yr old car
Sent from my ASUS_T00J using Tsikot Forums mobile app
- May 2016
- 18
August 24th, 2017 02:34 AM #25
- Jan 2020
- 1
January 21st, 2020 11:49 PM #26curious po ako kung na solved yung problem. ganito din kase yung experience ko sa pajero ko 2004 FM matic
Suzuki JIMNY [merged threads]
