Results 11 to 20 of 27
- Jan 2010
- 11
January 24th, 2010 05:52 PM #11sinara po yung tube sa pamamagitan lang ng pako.
hanapin nyo po yung tube na galing sa intercooler na naka-connect dyan sa tinuturo ng arrow sa picture. tapos lagyan nyo po ng pang sara o kaya pako. (rubber po yung tube na yun kaya pako lang yung ginamit nung mekaniko ko.)
- May 2006
- 424
January 25th, 2010 04:49 AM #12
January 27th, 2010 01:51 AM #13
[quote=Dudee;1406042]Mga mitsubishi experts and pajero owners...
My 2003 pajero has a knocking sound (tac-tac-tac), continously and loudly upon pressing the accelerator pedal in a rush (PA-BIGLA).. as early up 1.5 rpm, the knocking would start and never stop... BUT (weird part)... if I will accelerate it slowly.. kahit up to 3RPM, walang knocking sound...
I had two mechanics checked, they can't diagnose the problem.., ang sabi lang OVERHAUL daw kailangan... huhuhu...
any help will be appreciated... thanks[/quote
please check your injection pump timing, maybe it will help minimize the engine knocking. try to open your oil filler cap while engine running. if the smoke comes out the oil filler cap, then the mechanics are right due for overhauling. ( cause: loss compression) you may also encounter a hard start on your diesel engine.
January 28th, 2010 04:13 PM #14
~Hi Sir Dudee Good Day....ganyan din ung pajero namin na 4m40 engine..parehas na parehas tayo ng naging experience....ang probable cause nyan e ung butterfly ng tubro charger mo...since malaki-laki na din mileage ng auto mo madumi na cguro....the butterfly on the turbo opens when you press the accelerator pedal quickly...makapal na din cguro carbon nyang sayo kaya ganyan....Madaming auto mechanic ang hindi alam yan,kung ano ano papapalitan sayo e ganun pa din nman.hope it will help to you sir...
Drive Safely!
- May 2006
- 424
February 2nd, 2010 05:57 AM #15
- Mar 2010
- 13
June 17th, 2010 11:38 AM #16Hello Sir...
The knocking sound is due to either advance of timing. or your injectors need replacement. If I'm not mistaken you are also experiencing black smoke. You should have it calibrated.
- Jun 2010
- 76
August 10th, 2010 04:06 PM #17sir sakit na ng 4m40 yan knocking noise na yan during accelaration
kailangan palitan po yan ng timing chain,sprocet,chain guide..yan po ang cuase ng knocking sound..nun nasa diamond motor pa ako yan ang kadalasan complain ng customer knocking noise..yan lang naman po ang pinapalitan..kailangan buksan ang timing chain cover..kailangan lang po ingatan yun cylinder head gasket kasi madali masira yun at magkakaron na siya ng engine oil leak..sana po ay makatulong po ito sa inyu..tnx
- Jun 2008
- 41
August 13th, 2010 07:59 PM #18
- Jun 2008
- 41
April 16th, 2012 03:45 PM #20
Mga sirs I need your advice.Malakas din ang knocking sound ng 4M40 engine ko after ma OVERHAUL at mausok pati.Sabi ng mechanic ko wait until mag 1,500 (1,200 na ngaun) ang milage at pa calibrate/clean ang injection pump.Mahina pati ang hatak pag naka on ang aircon.
