Results 1 to 15 of 15
    Dec 2008
    help!
    Gud evening mga sir.. bkit po kya matagal mag shift kapag 60-70? bago naman po atf ko, dpat po bang nka batak ung cable na papunta sa transmission or medyo nakalaylay? tnx.
    May 2007
    That is the kickdown cable. Adjust the cable itself or bring it to good transmission shop to adjust it for you. Its an inexpensive procedure.
    ano ba any ride? pajero, strada, adve?
    ok lang yung 1st-2nd gear shifting? kahit your speed is gradual? not pushing the accelerator quickly?
    play with the kickdown tranny cable settings nalang. basta remember your old settings just incase...
    Dec 2008
    Quote Originally Posted by rion View Post
    pajero sir from subic, sa original setting ng local fieldmaster batak ung kickdown tranny cable, medyo magaspas ander kapag nakabatak sya, may alam po ba kyo nag aadjust jan sa mnla? kc taga province po ako.
    Dec 2008
    Quote Originally Posted by v6dreamer View Post
    may alam po ba kyong shop na marunong mag timpla?
  6. #6
    search the forums containing " j atutubo" pajero expert sa south side ng metro manila
    Dec 2008
    Quote Originally Posted by alwayz_yummy View Post
    big thnks... yumm yumm.
    Jan 2008
    kick down cable adjustment pag batak mas maaga mag shift ang transmission pag maluwag mas delayed pero pag may sira na transmission mo may "slipping" ka na mararamdaman
    normally pag adjust mo towards the throttle eh paluwag yan pag adjust mo away from the throttle eh pabatak yan..
    May 2007
    Quote Originally Posted by JEFF 009 View Post
    Sorry cant help you with this. Maraming may Pajero dito hopefully they might help you.
    Dec 2008
    salamat poh.
    Jan 2009
    [SIZE="3"]
    help!
    Yung sa akin more than 3000RPM bago magshift from 3rd to 4th gear at feeling mo parang nasiislip ang disk(o clutch). After naadjust ng isang mekaniko parang adventure lang ang bigat ng kaha ng pajero ko. Ngayon naman, after na ginalaw ng isa pang mekaniko when I tried to have tghe cable replaced kasi may 1 or 2 strands na putol e parang armored vehicle ang bigat ng kaha ng pajero ko.
    And now that JEFF mentioned it, after naayos ang acc cable ko, parang mas nakalaylay than before ang cable. I have yet to see what it looks like now.
    Can anyone recommend a good and reliable transmission shop para hindi ako iquote na naman ng as much as 80k when P200 tip lang pala ang solusyon (actually free pa nga iyan).
    Yung earlier post in another thread re problem ko kasi mahina ang hatak ng makina ko ang nagislip ang a/t "disks" which was diagnosed by several mechanics from weak pressure plate, pudpud ang cloutch so surplus na lang while others recommend repair kit. In summary from 50k to 80k ang quote sa akin but later, inadjust lang ang acc/kick down cable ko at ayos na. Magaan ang hatak as if gas engine.
    Then, when I tried to have my acceleration cable replaced (hindi na tuloy kasi they cannot find one of same length at iba ang dulo both ends) kinabit nila uli pero parang mabigat ang hatakl as if may karga. Pinaayos ko na uli pero bumigat pa lalo ang feeling.
    Unfortunately, hindi ko mabalikan ang nagayos nito kasi I forgot his face. May ibang problem kasi ako pinaestimate, told the mechanic my problem, and inayos niya after testdriving. Hijack din kasi estimate ng shop na iyan sa banawe so maybe last resort ko babalikan at tingnan ko kung mamukaan ko ang mekanikong iyan and try ko request na siya ang magayos. Pero last time I was there and I ask kung nagpapalit sila ng acceleration cable may kayabangan ang tono ng boses at ang pagkasagot sa akin na matrabaho iyan at hindi sila nagpapalit.
    Alam ko simpleng adjustment lang either pahigpit or paluwagin pero hindi ako yung DIY guy. Maybe I have to try din pero maybe it is more complicated than it looks kasi sa dami daming mekaniko na pinuntahan ko bakit iisa lang ang may alam tungkol sa relationship ng acceleration cable at hatak o gusto lang ako pagkwartahan? Pero parang hindi nila alam like itong huling mekaniko pinalala pa when dapat readjustment na lang kasi siya ang nagtanggal ng acceleration cable.
    [/SIZE]
    Nov 2007
    pag nag sslide na ba ang reverse pero ang forwarding is ok hindi na ba nakukuha sa kickdown cable yun? i mean mahina ang reverse nya? especially pag aatras ka ng paahon?
    Mar 2007
    pag hindi nag work yung kickdown cable adjustment sayo try mo i-check yung tps or lps(level position sensor) using a muti-meter. it's located on top of the injection pump(may 3 wires siya). ito yung nagcocontrol ng shifting ng a/t kung mabilis or mabagal.
    ganito din kasi problema ko dati sa subic pajero ko. lahat ng pinagtanungan ko gusto i-overhaul tranny ko. so try ko i-adjust kickdown cable pero ganun pa rin. tapos after some more searching yun lps pala problema. yun sa akin di na gumagana so binabad ko sa wd40 tapos may contact na uli after testing with a multi-meter.
    night and day ang difference niya!
    May 2009
    Nasubukan mo na bang galawin ang TPS sensor mo? Ganon din problem ko dati, adjust adjust lang sa kickdown at TPS ko. Dati sabi ng mekaniko eh AT tranny ko daw problem at kailangan palitan pero di naman pala.
    Jan 2010
    hello mga bro... i'm new here in this forum... ask ko lng if buying a two door pajero 96 model is a good one o hinde? 280 yung presyo... i'm from davao city... ok ba yung 4d56 na engine? thanks
4d56 automatic transmission adjustment
