Results 691 to 700 of 2688
- Dec 2013
- 20
April 16th, 2014 11:42 AM #691*monty
Panu ko kaya mareremove un? Nabubuksan ba un? Thanks
*gabriel
Ung gls-v namen nung dec nakuha may kasama na gps sd card.
April 16th, 2014 04:18 PM #692
April 16th, 2014 07:00 PM #693
- Mar 2014
- 147
April 16th, 2014 10:07 PM #694good pm.ung sd card knina pag start ng monty namin biglang nag eject ung sd card tapos nung sinalpak ulit ayaw na maread.may nakaencounter nb sa inyo ng ganun?plan namin dalin nalang sa casa by monday kasi wala naman nakalagay sa manual kung panu maauz.TIA
- Mar 2014
- 57
April 16th, 2014 10:10 PM #695Sir idolpuge, checked sd card from casa. Its standard size and not micro-sd fitted with adaptor. Its also marked inav and not transcend.
- Mar 2014
- 57
April 16th, 2014 10:15 PM #696Got GPS SD card when I bought MS GLX a couple of weeks ago. The SA said the card was not yet updated and that I had to update it using a pc. Unlike in your case the SA gave me the sd card.
April 16th, 2014 10:35 PM #697
Sa amin naman, nakuha namin yung unit last mar. 20, then to follow yung SD card,
after 2weeks, dumating na yung SD card from winterpine, at nasa sales agent yung SD card, hindi ko pa kinukuha dahil busy rin sa work, tinanong ko dun sa ahente namin kung pwede ako na lang mag-install ng SD card dun sa monty namin, ok naman at may go signal from the accessory part ng casa....
April 17th, 2014 01:48 AM #698
April 17th, 2014 08:38 AM #699
sir, sa tingin ko po na theres no way na mag eject basta yun sd card, unless iba na yun design nun sd card slot nyo compare sa ibang monty.baka di lang maganda pagka-lagay ng sd card.then parang sa computer,kapag inalis nyo yun source ng bigla without any proper procedure on ejecting. I suggest as mentioned by sir iceman, try to put when your HU is off or try inserting the sd card after you reset your HU. Kung sakali po wala pa rin, baka po na corrupt yun files nyo nun matanggal ang sd card. hope not kasi di na pwede talaga yun card. Hope I can help.
April 17th, 2014 09:06 AM #700
Drove my GLS-V 480 km from Manila to Bicol. From full tank may natira pang 30%. We were loaded with 4 adults and 2 kids and bagahe.
My gas cubby says I was doing 10.5 km/l. Not bad considering I am loaded and also marami road work sa kalye.
iwanttime
Hyundai Tucson Theta-II GLS A/T 2010
Mitsubishi Monterosport GLS-V 4x2 DSL A/T 2014
alas, much as we might want to rely on our noses, we may not use our noses to do emissions...
LTO accredited emission testing centers
