Page 53 of 197 FirstFirst ... 34349505152535455565763103153 ... LastLast
Results 1,041 to 1,060 of 3938
    Apr 2013
    #1041
    Mga boss, sulit ba ang GLX AT compare to MT?
    #1042
    Quote Originally Posted by Bengbeng View Post
    thank you sir zix, last na po anong type po sa high beam natin po?
    high beam is 9005/hb3
    Apr 2013
    #1043
    Quote Originally Posted by zix888 View Post
    thanks sir zix godbless po.
    Apr 2013
    #1044
    Anong brand ang reliable and saan tyo makakpagpakabit nito? Hi Beam as well as the Fog lamps
    #1045
    Quote Originally Posted by jetpilot320 View Post
    if you are going to replace it with a higher wattage halogen bulb, make sure the filament inside is perfectly centered, if not, focusing will be a big problem. so far i am just using the stock high beam
    Mar 2012
    #1046
    meron pa rubber damper yan sir na kapag nag max-out o palaging nag bottom out yung coil spring mo yun ang nag-absorb, tingnan mo rin sir baka pudpod na kaya kapag nalubak tumutukod kaya may tunog...
    i think sa mscp ka rin, check mo yung thread na rubber damper. binigay ko yung link...
    thanks sir. will check this out as well
    Mar 2005
    #1047
    Quote Originally Posted by ash0279 View Post
    i think another nuisance pag nalulubak monty natin e yung pag alog na spare tire.. yun yung na observe ko, though havent tried re-tightening yet yung lock.. try niyo rin check mga bros.
    Pano'ng alog ng spare tire sir? Ano ang tunog nya? Pwede mo naman higpitan yun kung sure ka na sa spare tire nga nangggagaling. Ako meron naririnig na parang squeaks kapag biglaan ang angat at bagsak ng gulong e.g. meron humps at hinayaan mo lang mag roll over meron faint squeak sound sa harap at likod. Pero pag umulan at nabasa ang ilalim, wala naman tunog kahit dumaan sa humps. So tingin ko it's case of lubricating some suspension parts. Ang tanong, ano kaya sa mga suspension parts ang kelangan i-lubricate?
    After my road trip to ilocos this weekend, papa underwash ako at try ko pa lubricate ilalim.
    Apr 2013
    #1048
    hello mga sir, newbie po ako.. tanong ko lang po about Montero Sports ( GLX 4x2 ) Navigation, nag download na po ako ng Software for SD card, pano po ba yun eh install? at saan po yung slot ng SD Card? at saka d po ba ma void yung warranty ng kotse pag ako lang yung mag lalagay? Thanks
    #1049
    guys, sa mga kapwa naka manual tranny, you might want to try the Ralliart stainless steel shift knob. Parang sedan ang shifting ko ngayon since medyo bumaba ang profile tsaka yung ergonomics ng handling plus the added weight of the steel knob i guess it helps me keying faster/smoother gear switches.. total cost 1.2k from sulit.
    Apr 2013
    #1050
    hello.. ask ko lng po... pag bago po unit ano po ba pwd kung palitan na body kits and accessories.. thanks po.. kung meron po kyong recommended na mga shops.. pki pm po ako.. salamat..
    May 2009
    #1051
    Hi! got my MS glsv 2013,March 27....same problem with ur GPS on the 2nd day ko napansin comparing to my garrmin gps na d nawawalan ng signal, except syempre sa tunnel or covered parking...palit GPS Unit...ok na as of this moment.
    May 2009
    #1052
    Quote Originally Posted by arvindeborja View Post
    Hi, nagkaproblema na ba kayo sa multimedia system ng monty nyo? yung sakin kasi yung gps this last few days walang signal tapos nagloloko. diko alam kung bakit samantalang ok na ok naman sya nung bagong bili. by the way 2013 montero sport gls-v po monty ko. tanong ko lang kung kailangan na nya ng update sa gps kasi nakalagay sa status ng gps next update will be january 2013. Tingin nyo balik ko sa casa dun ko na paayos? o baka may solution kayo. pashare naman .. Salamat in advance!
    Mar 2005
    #1053
    Quote Originally Posted by boybacolodnon View Post
    Hi, mind sharing where you got the downloaded files? Thanks!
    Mar 2005
    #1054
    definitely! with our terrible daily grind, AT is the way to go...
    Apr 2013
    #1055
    Quote Originally Posted by dsaint View Post
    HI, i downloaded it sa Genuine OEM =)
    Jul 2012
    #1056
    Hi Sirs, I just had my 5km PMS early this morning but when I checked the engine bay, may napansin ako (please see pictures):
    I noticed na parang may kinakalawang na part dun sa nakita ko. Is this normal? or possible na napalitan ang part na ito?
    MS bought last July 2012 only.
    Thanks po!
    #1057
    Quote Originally Posted by jc16 View Post
    Thanks po!
    Di makita ung images mo. O dahil siguro sa gamit ko?
    Jul 2012
    #1058
    Quote Originally Posted by keal01 View Post
    Sir, paki open in new tab na lang. Ayaw kasi lumabas nung image. Valid pa naman yung link niya. Ito po yung isa:
    ImageShack® - Online Photo and Video Hosting
    #1059
    We'll check tom for comparo. Nag pa-enigine wash ka na ba?
    Jan 2013
    #1060
    You mean the ver2.4 map from inav? Sa pc, open mo yun file then in the process you'd be asked to insert the SD card..ganun lang...around 5min depende or depende as bilis ng computer mo chief.
2013 Mitsubishi Montero Sport owners
