^ mag bosch or baldwin oil filters ka na bro. It's A bit more expensive but they're definitely both more of a quality product naman compared to vic oil filters.
I bought mine F-196 in Petron where i did my oil change.
Sent from my ONEPLUS A3003 using Tapatalk
Hi Sir Ravenblack.
Recently got the fuel filter change at a nearby caltex station. They were able to use the F-193 I bought earlier. Dinaan na lang sa matinding pihit para mag-tighten ang fuel filter container para di mag-leak.
Sir baludoy, does baldwin have fuel filters for the montero also ?
Thanks for the input guys.
^ yezzir. I use Baldwin model # bd 28 for my rig. Double filtration type sya
Hi.
Got another question re Check Engine Light.
Mine has been going ON / OFF intermittenly. Then for mga 2 to 3 months na naka ON all the time.
Changed oil about a month ago, then fuel filter a week ago. Still ON ang CEL.
Naka unioil naman ako most of the time. Sometimes CALTEX or PETRON.
Bought also mga OBD2 scanners. The cheap blue ELM scanner, Autel MS309 scanner (mga mas mura) & BAFX bluetooth scanner (from amazon).
All 3 scanners says my check engine light is OFF and there are no errors. But the CEL is ON.
Anyone bought a scanner that worked well with Montero in general ? Also, where can i have it scanned aside from CASA ?
Thanks in advance.
Anybody here tried to install a headrest for the middle seat 2nd row?
but you need load resistors for the turn lamps(leds),
(diy ko lang)[/QUOTE]
Hi Zix,
Pwede po malaman kung paano ang connection ng diy na load resistor sa mismong system na?
Kahit simpleng diagram lang po...
Nag palik kasi ako ng LED ngayon, naging fast blinking na..
Thanks po... akala ko kasi parallel sya icoconnect... pero di ko muna tinuloy...
Connecting it in parallel with the LED bulb will effectively lower the R - even lower than the current LED bulb resistance.
Bro - you need to increase the resistance as seen by the circuit and the capacitor,- and so you place it in series with the LED bulb/light. Just cut the wire just before the socket and connect it; Works on either of the [2] lines
Have not really tried it,- just theory based on this...
T=RxC...
Make sure that the aux cable you are using is AV. Try this. TV Plus to Car Monitor AUX Socket Direct Cable GZ-8 5 3.5mm AV Baby to Baby Plug 1.5meters | Lazada PH
Sent from my SM-G975F using Tapatalk
I have an question/issue with my 2013 montero. Specifically the power side mirrors… when I activate my power side mirrors the passenger’s side mirror folds open to its correct position while my driver’s side mirror folds open too much, it folds open to about 180 degrees but when I press the button to fold the side mirrors back in, both side mirrors fold in just fine only when they fold out the driver’s side folds out to 180 degrees while the passenger side mirror folds out just fine. Is there a way synchronized the side mirrors without having to open up the driver side mirror? Thank you.
Hi Incy, nabali na yung stopper niyan kaya open wide na siya. Dati, nangyari na sa Montero namin yan. Pansamantala, hinahawakan lang namin kapag nag-open para tumigil sa desired angle hanggang pinalitan na rin namin ng replacement side mirror. We asked casa about repair, palit buo rin ang suggestion kaya naghanap na lang ng cheaper alternative online
Sent from my Xcover Pro using Tsikot Forums mobile app
