Page 345 of 345 FirstFirst ... 245295335341342343344345
Results 6,881 to 6,900 of 6900
    Apr 2012
    #6881
    hello mga ka-monty, sa mga may service manual ng Gen2 (GTV 4x4 2012 model), i'm looking for the part nos. of front left ABS sensor and Input Turbine sensor. paki-share naman if meron kayo. tia
    Sent from my SM-G960F using Tsikot Forums mobile app
    Mar 2018
    #6882
    try using parts souq website. You can enter the brand and model of your vehicle and should be able to find the part number you're looking for.
    Sent from my YAL-L21 using Tsikot Forums mobile app
    Jul 2017
    #6883
    Bro paki check lang ito kung tama ba sa hinahanap mo (:
    Apr 2012
    #6884
    Quote Originally Posted by DAD525 View Post
    thanks bro, i appreciate it. btw, saang online shop yan? can you please pm me the link. mga nakikita ko sa shopee and lazada are mostly generic copies, baka mali mabili eh sayang
    Apr 2012
    #6885
    Quote Originally Posted by RavenBlack View Post
    thanks bro, will do[emoji106]
    Jul 2017
    #6886
    Sa Lazada ko lang nakita yan... doon sa kinukuhaan ko na online store.. They sell OEM Mitsubishi parts. ( pm sent)..
    Apr 2012
    #6887
    i got your PM bro. again, salamat!
    Jun 2012
    #6888
    Hi guys, nagloloko na ung stock touch screen and mukang time na para palitan. Would like to get some feedbacks sa magandang android aftermarket.
    Basically dapat
    1. android auto and apple carplay compatible via bluetooth or usb cable.
    2. malinis or stock looking
    3. can download apps and watch youtube, netflix etc and of course kaya mag data or connect sa naka data for internet access.
    May mga nakikita ako sa FB na from Thailand na android replacement around 8k and up iirc but just want to do my DD.
    Jun 2012
    #6889
    Did anyone experience na hindi na crisp and loose na ung turn signal/headlight dimmer switch, specifically when flashing hi beam? Is it for replacement or repairable pa?
    Sep 2024
    #6890
    Quote Originally Posted by pingpongdad View Post
    awaiting feedback here also about the alarm. the manual for the alarm which came with the unit refers to a valet switch and a valet mode? but our keys have only the lock and unlock buttons and the car manual does not mention a valet mode. i wonder if the manual is for the alarm installed? it says " PA130P2-V4 MANUAL FOR KEYLESS ENTRY UPGRADE SYSTEM". do you have the same?
    thanks a lot
    Alam mo sir kung anong brand nung car alarm?
    Jan 2025
    #6891
    ...same issue po ung sakin...pano po naayos ung beeping sound?...salamat po sa pagtugon...
    May 2017
    #6892
    Quote Originally Posted by unclepeputs View Post
    dalawang beses ko na lang pinipress ang lock kapag iniiwan ko para turn-off ang alarm.
    Kapag sisindihin mo na ang Montero, wag mo munang sarado ang pintuan para hindi ka uunahan sa pagactivate ng alarm before turning the keys. Kasi kapag naunang nactivate ang alarm mapapansin mo ayaw nang magstart ng Montero
    Jan 2025
    #6893
    ive got a montero gtv 2012 as i used it yesterday i heard a series of beeps but no indicator lights up in the panel or dashboard. it beeps 10 times then it stops and comes back on after a couple of minutes. It does a couple of cycles then beep becomes faster for around 20 beeps again after a couple of minutes and so on.
    Has anyone experienced this issue before? what may be the probable cause of the issue?.
    Jan 2009
    #6894
    Pretty sure it's the TPMS module. Baka hindi na gumagana yung TPMS sa tires mo. I had mine unplugged nalang since, afaik, disposable yung oem TPMS na nakalagay sa loob ng gulong. Nasa ilalim ito banda sa tapat ng steering wheel.
    Jan 2009
    #6895
    Just guessing....
    Maybe it's the passenger-side seatbelt warning? Did you put a heavy object on the passenger seat? The system could be mistaking it for the weight of a person but with the seatbelt unbuckled.
    Jan 2009
    #6896
    Just guessing....
    AFAIK, wala pong seatbelt warning ang GTV 2012. At least yung sa amin wala. I could be wrong pero I'd love to have this feature as well sana. I'm 101% sure it's the TPMS module from my first hand experience.
    #6897
    What did/are you using for the ATF of your MS? Ours is 2015, before the current model.
    Manual states Mitsu ATF SPIII. Any equivalent/replacement ATF for this?
    TIA.
    TIA.
    Boss Pat, madami namang SPIII compliant na oils like those from Castrol Multivehicle or Valvoline Maxlife multivehicle. Okay naman mga yun if you don't want the Mitsu sold ATF oil. Pero better stick with SPIII rated ATF imho.
    #6899
    Thanks for the feedback, bro Ry_Tower. Planning to do it soon, as the vehicle's mileage is nearing 45KKm.
    God bless, bro! Take care always!
    Keep safe always too. Mukhang hindi bugbog MS mo ah. 45K kms pa lang, sakto nga sa 50K replacement ng tranny oil.
2012 Montero Sport Owners
