Page 338 of 345 FirstFirst ... 238288328334335336337338339340341342 ... LastLast
Results 6,741 to 6,760 of 6900
    Dec 2018
    #6741
    mga boss tanong ko lng po, gusto mg palit ng mags 20” from 18” na stock gusto ko po medyo off road na naka off set medyo badboy na macho ang dating prng gnun hehe! kailangan ko pa po bang mag palit ng shocks? target size ko po 20” then terra grappler na 265 60 R20 na BR po. if ever na na mg palit ano po maganda brand? na nasa 20-35k po saka saang shop pwede mg palagay yung recommendation niyo mga idol maraming salamat po tlga! god bless and more power! ahh montero 2012 po pla, gusto ko rn sana mg palit kasi laging full load ang sasakyan pag summer saka pg my family outing.
    Apr 2012
    #6742
    Quote Originally Posted by lenard977 View Post
    check out fb page of blueline car accessories, plenty mags designs and tires to choose from
    #6743
    Has anyone experienced unusual noise on the transmission when downshifting or when lifting the throttle? I have a 2012 GLSV model with 110K mileage. I started hearing this a few weeks ago. It is noticeable when you are in manual mode and you rev-up and lift on the throttle before up-shifting. But I first heard the noise when in automatic and coming down and incline when it sort of engaged engine brake and there was an unusual noise.
    Apr 2012
    #6744
    Quote Originally Posted by efpu View Post
    is it a whistling sound? if yes then baka yung wastegate ng turbo sa bandang harapan yung sumisipol hindi sa transmission. i maybe wrong since 110k kms na unit and you hear the sound lang kamo few weeks ago, unless its a used unit...
    Curious lang, do you have a turbo timer installed bro?
    #6746
    No it's not a whistling sound..it's more like something mechanical that is loose or gears that are not latching correctly. It's not very loud but you can hear it especially when the radio is off. And it comes out only when you rev high while moving and lifting the throttle where it somewhat engine brakes. it does not come out when you rev it high when standstill where you can hear the turbo whistling...and it's not a used unit, I've had it brand new.
    #6747
    No turbo timer installed. Everything is stock except for tires and batteries and unit is casa-maintained.
    Apr 2012
    #6748
    i see. it might be an issue with the clutch or transmission then. have it check by your trusted mechanic or casa.
    i have the same year unit (gtv 2012) at close to 190k kms but i don't experience such thing.
    #6749
    It’s normal, we call it turbo flutter
    #6750
    Quote Originally Posted by zix888 View Post
    Hi Zixx - after hearing sound compilation of turbo flutter on youtube, the sounds are similar to what I am hearing. I do hope there's nothing wrong with the transmission or anything. But I will observe. Question: how come I have not heard this before and it started only recently?
    Jan 2019
    #6751
    Palitan mo lang ang MAF sensor. Ok na yan. Or if ok sayo na may CEL, tanggalin mo na lang ang plug, ok lang yan
    Sir zix magtatanong po sana, may connection ba ang MAF sensor sa mild choking during acceleration? bago na fuel filter malinis egr at bago na din scv. TIA.
    Sent from my MI MAX 2 using Tapatalk
    May 2005
    #6752
    hi, may naka experience na po ba sa 2012 monty gls-v na bigla na lang walang hatak at naging mausok? pero ngayon ok na naman. sumusumpong lang. no check engine light, bagong linis egr ... salamat po
    Jan 2019
    #6753
    Quote Originally Posted by allstock93 View Post
    parehas tayo ng problema bro. nagpalit na ako scv pero after 2 days sinusumpong na naman.
    Jul 2017
    #6754
    Quote Originally Posted by adjong View Post
    You may try to backread the pp671-673 of this thread. This might give you some idea.
    Apr 2012
    #6755
    my 2012 GTV odo as at 9th Jul 19 and still in very good running condition[emoji120] i don't recall if i encountered issues with faulty scv, most of the time, the culprit is dirty fuel filter kung may CEL o kaya abnormalities sa takbo. i do clean the air filter and maf sensor regularly. egr naman was blanked/blocked since long time ago and i don't even bother na baklasin na, malinis naman last time na sinilip ko.
    parang more than half ang engine temp? normal ba yan?
    Jul 2017
    #6757
    In my opinion, its still normal as long as it stays near or at the center of the gauge. But if it moves further up towards H, then something need to be
    checked before it reach the H.
    Apr 2012
    #6758
    normal naman sa tingin ko, hindi pa naman lumampas sa ganyang level. dapat ba sakto sa middle or less?[emoji848]
    napagoogle ako out of curiosity. damn that mitsu temp gauge! its normal. alam ko meron centerline and needle should be below that for some cars.
    Jun 2018
    #6760
    Nablank na egr mo sir?
2012 Montero Sport Owners
