I work in Makati and live in Alabang, so around 70% of my drive is in SLEX/Skyway.
Sabi din ng mechanics from two different stores (where I bought my oil), they attended the seminar for Mobil oils, and they said that the oil I'm using can last up to 20T kms, pero dahil matraffic daw sa Manila, 15T is enough.
But I think what I'm doing is not applicable to those who seldom use their cars or those who have low mileage kasi baka it will take more than a year before you change your oil (which I think is bad if your oil stays for more than a year in your engine). In my case, I usually drive 5T kms every 3 mos, so the usual interval of my change oil is 8 to 9 mos (14T kms).
The user manual provides for severe vs normal usage scenarios and Time vs distance traveled.
Sent from my MI 5 using Tapatalk
MONTERO 2012 GPS UPDATE
http://www.inav.ph/update_instruction.php?nav=MMV3
JUST FOLLOW INSTRUCTIONS..
mga sirs pwede po bang gamitin ang mag175w90 sa manual transmission ng montero sports model 2012
While cruising at night with headlights on. Normal ba pag mas madiin ang apak or aarangkada lumalakas yung ilaw (headlights and fogs)?
Sent from my SM-G930F using Tapatalk
Ill try to monitor further. Pero pag bagong start kitang kita yung paglakas ng ilaw pag aapak sa gas e. Since second hand nabili yung unit nagpalit narin ako battery 3 weeks ago. Sabi ng motolite okay naman daw charger though hindi ko na visual check yung gauge nila while testing. Pacheck ko nalang ulit kung sufficient charging ng alternator ko. Sana wala maging problema long drive nanaman bukas.
I don't know with 75w90, pero I've used 80w90 before and I think it's too thick, had a hard time shifting to 1st gear in the morning, specially when down shifting from 2nd to 1st. Pinalitan ko agad after two days with the recommended 75w85 GL3 and it instantly goes back to normal shifting. Be wary of the API more than anything, tranny calls for GL3 but I think we can use GL4, definitely don't use GL5 as it will hurt your synchros. GL5 are for our differential.
Pagbalik ko na mapacheck to bro. Sana wala maging problem sa byahe. Pero nabyahe ko na Manila-Pangasinan-Zamables back to Manila And Manila - Tarlac balikan. Wala naman problem. Pag start sa umaga 1 click lang din. Noted Binalonan bro. Thank you!
Makikisabat sa usapan sir. . . I think it's faster. . . And cheaper if urdaneta exit going to LU instead of exiting binalonan.
Sent from my GT-I9300 using Tsikot Forums mobile app
