Results 3,041 to 3,050 of 6889
Tsikot Member Rank 1
- Jul 2009
- 4,090
August 15th, 2012 08:13 PM #3041i'll definitely take your advise sir., anyway, ask ko lang kung anu kaya problem kung mat lumalabas na "No Signal" dun sa screen when in reverse, nagpalagay kasi ako ng reverse cam., nasa 2nd basement floor parking ko and when i shifted to reverse, lumabas yung screen with no problems then after a few seconds, all black na sya then may "No Signal" na lumalabas., san kaya problem nun mga bossing? connected ba sa gps or something yung reverse cam kaya ganun.... sensya na mga sir, mejo slow ako when it comes to this. thanks sa advise in advance....[/QUOTE]
ganyan nangyayari pag hindi siya nakapagstart up pa tapos reverse ka na. medyo matagal kasi siya mag start up
- Jul 2012
- 11
August 15th, 2012 08:17 PM #3042Guys my monty is GLX NON VGT AUTOMATIC, ask ko lng ilang minutes dapat naka idle before switch off ang engine? Wala ako turbo time kasi non vgt naman. Also headlight pag umuulan at bukas ang ilaw medyo may moist or medyo malabo, ganun din ba sa inyo? 2 weeks pa lng monty ko.
Pls advise guys. Thanks.
- Jul 2012
- 11
August 15th, 2012 09:07 PM #3043Guys pwede din ba ma activate sng searbealt sensor sa GLX NON VGT MATIC?
- Jul 2012
- 88
August 16th, 2012 08:08 AM #30441 to 2 minutes, or depende sa paggamit mo ng turbo. Kung papasok ka pa ng subdivision bago mo igarahe car mo, kahit hindi mo na i-idle kasi mag cool down na yun habang cruising ka sa subdivision nyo basta slow down ka lang.
Better ask Sir Zix.
I think hindi sya connected sa GPS since "video out" lang naman ang reverse cam. Better ask winterpine kung sa kanila mo pinakabit.
- Jul 2012
- 11
August 16th, 2012 09:07 AM #3045
- Jul 2012
- 11
August 16th, 2012 09:15 AM #3046
- Jul 2008
- 72
August 16th, 2012 12:16 PM #3047Question: Ano pong type of halogen bulb yung head light and fog lights ng monty? wattage? Thanks.
- Oct 2005
- 25
- Jan 2006
- 22
August 16th, 2012 03:35 PM #3049Hello po mga sir, i have a 2012 gtv, recently biglang naging cloudy yung image for my reverse camera. Even after wiping the lense. Has anyone experienced this? Tia
- Aug 2012
- 10
August 16th, 2012 05:19 PM #3050Helloe, here are some answers to your question.
q
Benefits
This sort of transmission is ideal for someone who wants to be able to control the power the vehicle has, by being able to down shift or shift up, when the driver deems it to be necessary. The Sportronic transmission will hold the gear you select for as long as you want it to, which is an advantage over traditional manual transmissions.
Xiaomi E-Car
