Page 291 of 345 FirstFirst ... 191241281287288289290291292293294295301341 ... LastLast
Results 5,801 to 5,820 of 6900
    Sep 2013
    #5801
    Quote Originally Posted by mar04 View Post
    2gb lang sir, ayaw nga nila i swap to 4gb sa winterpine e. bibili daw if ever even if under warranty unless 2014 ung model.
    pero naupdate parin inyo to Q3? pinaupdate ko dun sa inav na company mismo dami pang hinahanap saking requirements para namang may kinalaman yung sasakyan ko doon
    Jul 2012
    #5802
    madali lang bro, lagay mo sa pc or laptop mo then sa My Computer dba may drives na (C, (D etc, i right click mo kung sang port sya naka lagay, most common is nasa (F siya, pede ring E or J. Right click mo then choose format then wait mo lang matapos then i update mo na.
    Thanks Sir Mar, try ko to. Natry ko update thru 2013 mababa ang laman kompara sa 2012, same parin.
    Sent from my GT-I9100
    Jun 2012
    #5803
    Quote Originally Posted by Louie Anson Ng View Post
    yes sir, wala pa ba naka try ng reformat technique? well ako ngayon ko lang din nalaman ung reformat tech. lol. bat hinanapan ka sir? marami ba ung sd card na pina update mo?
    Jun 2012
    #5804
    Quote Originally Posted by mangkas1178 View Post
    no problem bro. balitaan mo kami kung ano nangyari. kasi hindi ko naman nakita kanina sa winterpine at hindi ko pa na try ung reformat technique.
    Jun 2012
    #5805
    double post
    Aug 2005
    #5806
    Mine is working fine sir, I went to winterpine earlier and had them update it. I inquired about the formatting, and just as you said, it will not erase the unique id of the sd card but just be sure to have a back up. You can try calling them or inav on how to fix your sd card and you can also pm me your email, I have a back up file here if you want.
    pm sent sir...
    #5807
    I tried twice kanina update.wala pa din.
    Jul 2012
    #5808
    Sir Mar tried ko reformat ang labas lahat na uploaded file sa SD card will be deleted, so 505.14MB ng 2012 models at 503.9+MB ng 2013 models pasok. D ko na tinuloy ang update 265 MB ang free space sa 1.83Gb (2.0Gb) Sd card. Anong ginawa ng winterpine sa deleted file mo after updating.
    Jun 2012
    #5809
    what do you mean exactly ng 2012 at 2013 500mb files mo? if na format mo na yan then nilagay mo ung latest update nasa around 1.80gb ang makakain na space kasi ganun saken. then ang folder is Genietek at navigation na lang. So in short hindi ka nag update sir? tama ba ko?
    nung nireformat un deleted na lahat ng previous na laman, if you are referring nung nasa Favorites ng gps, nandun pa naman. nakalimutan ko itanong how come nandun pa e finormat nga nila.
    PS: Nasa 479mb lang ung from winterpine nung zinip ko compared sa 517mb from iNav ngayon ko lang napansin.
    Jul 2012
    #5810
    Sir ang file ng Q3 sa 2012 models ay 505.14 Gb ang sa 2013 models ay 503+Gb na try ko update dito sa dalawa parehas ang result " insufficient space" after completion of loading. Ang Sd card ko ay 2Gb with available space of 1.83Gb ang free space ay 205Mb nalang so with the above Q3 update file hindi na kakasya. Binura ko ang distorted file din ibinalik ko ang file na hanggang Q2 (2012 mod) update. Kong parehas lang po 2012 model ang Sd card mo, baka kako hindi na binalik ng winterpine yong file with Q2 update ng makapasok lang ang Q3. Ilang bites na ngayon laman ng Sd card mo? Mine is 1.565Gb up to Q2 update lang.
    Jun 2012
    #5811
    ahh so hindi mo siya finormat. kasi pag finormat mo yan magiging 2gb na free space mo. then right after mo i format saka mo i install ung update or i extract mo then i paste mo ung content dun sa sd card mo na na format mo na (GenieTek at Navigation folder dapat). All in all 1.80gb something ang nakaing space sa sd saken. No need na ipaste mo ung mga previous update just the latest one.
    Aug 2005
    #5812
    Winterpine did a backup of your "user" folder (path: GenieTek/data/phl) prior formatting. In which they pasted it on the mentioned path after loading the Q3 update. Kaya sir, nandyan pa yung favorites mo. Yung "user'" folder contains all your saved favorites.
    Jun 2012
    #5813
    Quote Originally Posted by leinahtan View Post
    I see, thanks sa info bro very informative.
    Jul 2012
    #5814
    Masubok ulit. Thanks.
    Jun 2012
    #5815
    take note of what sir leinahtan said. para at least nandun pa ung sinave mo sa Favorite. Balitaan mo kami after.
    Jul 2012
    #5816
    Sir Mar, reformat ng Sd card default Fat available space of my Sd card 1.83Gb then proceed download of update on montero 2012 took more than an hour. After that update to Sd card upon completion, failed and contact winterpine etc. ang lumabas so failure parin.
    Na contact ko ang winterpine technical sa casa malapit sa amin and ni refer ko 'tong Q3 update na d makapasok sa 2Gb Sd card. Hiningan ko kong ano ang magiging remedy ng winterpine. Update nya lang po ko. Wala pa daw syang hawak na copy ng Q3 update at parang kanina lang nalaman na may bagong update na ng navi.
    Mar 2012
    #5817
    So this mean talaga po na much better to use pa rin yun Q2 since most of the inav user failed updating their sd card. correct me na lang po mga bossing if im wrong.
    Jun 2012
    #5818
    Quote Originally Posted by the_mechanic View Post
    ano kaya meron? may mga ibang tsikoteer na gumana naman right after updating. ako nung nag update ako error din e. nagkataon lang na dumaan ako winterpine at sila nag update ayun ok naman. Sinend ko nga ke sir leignahtan ung contents ng sd ko kaso hindi daw gumana sa kanya. pm nyo or post nyo email nyo send ko senyo ung contents nung saken baka gumana senyo if you want. then either call iNav or winterpine or wait for the 'fixed' version.
    #5819
    Sir pahingi naman try ko baka palarin.
    jandal18*yahoo.com
    Jun 2012
    #5820
    Quote Originally Posted by jalen View Post
    jandal18*yahoo.com
    check your email bro
2012 Montero Sport Owners
