Page 290 of 345 FirstFirst ... 190240280286287288289290291292293294300340 ... LastLast
Results 5,781 to 5,800 of 6900
    Feb 2011
    #5781
    Quote Originally Posted by zix888 View Post
    year model sir?
    Montero GlsV 2011 sir zix888
    Jul 2012
    #5782
    May bagong update na ang GPS, Version 2014-03 dtd Oct 31, 2014.
    Sent from my GT-I9100
    #5783
    Quote Originally Posted by monterick View Post
    http://tsikot.com/forums/mitsubishi-...ml#post2420519
    Aug 2005
    #5784
    Quote Originally Posted by mangkas1178 View Post
    Thanks for the heads up sir mangks. Ang laki ng file size 505mb.
    Jul 2012
    #5785
    Sir leinahtan kumasya ba sa SD card mo? 1.56GB sa akin plus 505.14 MB nag insufficient disk space na.
    Jul 2013
    #5786
    guys is it okey lang po ba ang 3" straight pipe sa engine natin? or much better kung may muffler?
    kung ang paguusapan po eh performance
    TIA!!
    Aug 2005
    #5787
    Kasya, if you reformat your sd prior pasting the software and update. My sd card's capacity is 4gigs. However, I cannot make the Q3 update to work. Map is distorted so I reverted back to the Q2 (June 2014) version. May problem yung Q3 update. That's on my side, hindi ko alam sa iba. Awaiting for a fix on that issue.q3-update.jpg
    #5788
    Aug 2005
    #5789
    brader, pahiram ng mac mo, he he.
    #5790
    Quote Originally Posted by leinahtan View Post
    hehe, i am sure maglalabas sila ng bug fix diyan
    Jun 2012
    #5791
    Sure ba yang format na yan sir? Hindi ba mawawala ung file na naka engrave sa sd natin (the one para hindi gumana sa ibang sd kahit i copy paste mo ung laman ng sd natin?). 2gb lang din kasi sd card ko so if gusto ko ung 4gb bibili ako sa casa or pwede swap then add? lol.
    #5792
    Quote Originally Posted by mar04 View Post
    kung under warranty pa bro dalhin mo sa winterpine, ask for 4gb pwede yan
    Jul 2012
    #5793
    2Gb lang sd card ko kaya d na makapasok ang bagong update, 1.56Gb na ang laman.
    Aug 2005
    #5794
    formatting doesn't erase the unique id of the sd card itself. do not attempt to format it without backing up first the initial datas. I tried formatting it then loading the q3 update and soft, the map display went distorted and program response is way too slow, so I formatted the sd card again and loaded the previous Q2 update. I guess, my GPS is stuck on this vers. until a fix on Q3 becomes available.
    Jun 2012
    #5795
    Mine is working fine sir, I went to winterpine earlier and had them update it. I inquired about the formatting, and just as you said, it will not erase the unique id of the sd card but just be sure to have a back up. You can try calling them or inav on how to fix your sd card and you can also pm me your email, I have a back up file here if you want.
    Sep 2013
    #5796
    ilang gb yung sd card nyo sir?
    Jun 2012
    #5797
    try mo bro i format, basta i back up mo muna. then saka mo install.
    Jun 2012
    #5798
    Quote Originally Posted by Louie Anson Ng View Post
    2gb lang sir, ayaw nga nila i swap to 4gb sa winterpine e. bibili daw if ever even if under warranty unless 2014 ung model.
    Jul 2012
    #5799
    Yan ang malaking problema d ako marunong magreformat. Stay nalang ko muna sa june update. Thanks.
    Jun 2012
    #5800
    madali lang bro, lagay mo sa pc or laptop mo then sa My Computer dba may drives na (C, (D etc, i right click mo kung sang port sya naka lagay, most common is nasa (F siya, pede ring E or J. Right click mo then choose format then wait mo lang matapos then i update mo na.
2012 Montero Sport Owners
