Page 280 of 345 FirstFirst ... 180230270276277278279280281282283284290330 ... LastLast
Results 5,581 to 5,600 of 6900
    #5581
    Quote Originally Posted by NAML View Post
    Sir, may you pm me the cost for these including fmic and egr blanking. I think my almost 3 yr old GTV can immensely benefit from these. Pls include also your shop address. Thanks
    pm sent sir. thanks
    Jul 2003
    #5582
    may update na sa inav.ph; 18june2014.
    kaso ang laki ata 493mb. MMV3_27.exe
    Aug 2005
    #5583
    Quote Originally Posted by kurt View Post
    thanks kurt. hmmm... malaki nga yung file size.
    Apr 2012
    #5584
    Quote Originally Posted by zix888 View Post
    pm sent sir. thanks
    Got your pm, sir. Will try to sked in one of the weekends in july. Weekday schedule is a little tight. With the exception of piggyback, kaya ba yan sir ng half day? Thanks
    #5585
    ok noted. 3hrs sir for the FMIC (if stock, no relocation of horns, bullbars etc)
    Apr 2012
    #5586
    Quote Originally Posted by leinahtan View Post
    Apart from maps update, meron din ba updates na ginagawa sa OS nun AVT natin?
    Posted via Tsikot Mobile App
    Aug 2005
    #5587
    Quote Originally Posted by wing211 View Post
    This latest update, meron. The theme has changed. Was able to update it manually. Ayaw mag-proceed pag yung updater ang ginamit.
    Apr 2012
    #5588
    sa mga may 4x4 units na hindi naman sumasabak ng serious offroading, kailan niyo ginagamit ang 4x4 mode. ako kapag dumadaan lang ng rough road sa probinsiya at saka kapag medyo baha ang daan naka 4x4 mode ako. minsan nakakalimutan ko pa, patapos na yung rough road, akyatan o baha saka ko lang maalala dapat pala nagshift ako sa 4x4
    Jul 2012
    #5589
    Ginagamit ko kapag umuulan, paakyat ang kalsada, bago umakyat ng tulay baka d pa nakaahon ma stuck up na ang traffic, minsan kasi sa templa ko ng clutch at accelator pedal aatras pa bago umubante. Natry ko na rin sa Talisay-Tagaytay bituka ng manok.
    Sent from my GT-I9100 using Tapatalk
    Apr 2012
    #5590
    Parehas tayo bro...I always forget to use it pero dapat gamitin nga from time to time.
    Apr 2014
    #5591
    Sir zixx..pa pm naman po ako ng egr blanking, optitron, cabin filter, k&n air filter
    Apr 2012
    #5592
    Quote Originally Posted by mangkas1178 View Post
    MT ba unit mo sir? later on makakabisado mo rin yang clutch, accelerator at hand brake release sa akyatan. di ko pa naakyat yang talisay-tagaytay, exciting daw I drive. baguio (kennon, marcos), isabela (dalton pass), baler, naakyat ko na mg zigzag roads diyan.
    kaya nga bro, minsan kahit maiksing rough road o basta basa ang daan, 4x4 mode na para naman magamit...
    Jul 2012
    #5593
    MT Sir, pagmedyo mababaw lang diin ng accelator pedal parang may slippage muna ang differential. Hindi nyo ramdam yan sa LSD differential.
    #5594
    Thanks Sir monty_GTV for the advice about sa 4wd
    Dapat nagagamit rin yung 4wd system, yung sa amin, kahit bihira patakbuhin yung sasakyan, pag dinadala ko po, activate ko po yung 4H mode, kahit paano ma-lubricate din yung gear transfer ng 4wd,
    Sir mangkas1178,
    nasubukan nyo na po ba yung 4HLc saka 4LLc?! hanggang 4H pa lang yung na test ko...if ever kasi pag may tyempo na merong parking area na unpaved, gusto ko sana i-test yung 4HLc, ang concern ko lang kasi dahil nasa 400NM torque ng engine (MT), pag nasa low gear, malakas yung punching power. pag tatakbo in 1st gear..
    Jul 2012
    #5595
    Quote Originally Posted by playplugg View Post
    Sir mangkas1178,
    Nasubukan sa rough road lang. Huwag lang kalimutan na ibalik sa 2H mode bago magpark. Last time nakalimutan e disengage ang 4x4 ng pinaandar ulit pigil umusad sa first gear at garalgal tunog ng front differential, okay naman after few seconds. Buti lang d gaano katagal park ko.
    #5596
    Thanks Sir mangkas1178 for the good info and advice..
    If ever na magamit ang 4wd, during rainy season or unpaved road, will double check, between the transfer case shift, and the 4wd light indicator before turning off the engine!
    Safe driving sa atin Sirs always! lalo't na rainy season already! medyo magagamit na yung 4H mode hehe.. for safe traction..
    Apr 2012
    #5597
    yup, sayang naman yang feature na 4x4 kapag hindi nagagamit
    have you tried shifting from 2H to 4H while running? at what speed? at lower speed you have to stop, put in N then saka lang mai-shift from 2H to 4H.
    btw, the brochure says,
    2H (2WD high range) - when cruising down the highway or just going across town, it shifts into rear wheel drive for smooth, quiet, fuel efficient performance.
    4H (4WD high range) - when the weather turns bad and the roads get rough, switch to 4H mode for added traction. the dynamic front/rear torque splits adjusts for to give you greater control for high speed driving.
    4HLc (4WD high range with locked center differential) - keeping you on track even in rugged or slippery conditions, it distributes power equally to for all 4 wheels for offroad excitement with steady sense of control.
    4LLc (4WD low range with locked center differential) - switch to 4LLc when you need the tractor like crawling power. maximized low-end torque pulls you through even the roughest terrain, stickiest mud and deepest snow.
    http://www.mmpc.ph/montero-sport-gtv...t/brochure.pdf
    Jul 2013
    #5598
    Mga sir makikisabad lang.. Shifting from 2H to 4H can be done on the fly 100kph below.. Just release tha gas pedal ang the wheels in straight position..
    From 4H to 4L ans vice versa, you have to stop the car, shift to N and wheels straight..
    Ako since nandito ako province, basta umulan na at madulas na hiway, i use 4H. Lalo na sa abrubt acceleration during overtaking..
    Jun 2014
    #5599
    Alin po kaya mga Sir ang mas okay na ipagawa para mawala po yun mausok na bigla acceleration for overtaking at uphill driving or pag naka high speed sa Highway... EGR Cleaning Package ng Mga Mitsubishi Dealer Service Center(CASA) or EGR Blanking ni Sir Zixx? Naka 2011 Mitsubishi Montero Sports GTV kami. Hope for your reply mga kaibigan.
    Jul 2012
    #5600
    Quote Originally Posted by XandersMonty View Post
    Sir, kong ako sayo pm Sir Zixx for egr cleaning and blanking plate installation.
2012 Montero Sport Owners
