Page 266 of 345 FirstFirst ... 166216256262263264265266267268269270276316 ... LastLast
Results 5,301 to 5,320 of 6900
    Feb 2007
    #5301
    Yung mas shorter sir(31mm).
    Yung front room lamp is 3 T10.
    Sent from my Nokia 5110 using Tsikot Forums
    Jun 2007
    #5302
    Sir confuse lng po?
    According po kay sir prince777.
    festoon type bulb 31mm= front room 3x po + rear + laugauge
    door sidings,park light and plate light is T10 w5w= 8x po.
    Correct me if I`m wrong.
    Thanks a lot..
    Feb 2007
    #5303
    Quote Originally Posted by crisfer12 View Post
    Sir confuse lng po?
    Thanks a lot..
    Type it wrong sir, front is T10, middle and rear are Festoon 31mm.
    Posted via Tsikot Mobile App
    Jun 2007
    #5304
    Thanks a lot sir for the correction.
    Sir prince777 ask ko lang po upgrade interior lights? Where and how much po?
    Feb 2007
    #5305
    Mostly online ko lang binili sir. Either ebay or amazon or sa china online sellers.
    Some of my exterior lights. Cree "daw" na LED.
    Apr 2012
    #5306
    Quote Originally Posted by mangkas1178 View Post
    Thanks Sir Monty sa concern.
    Sent from my GT-I9100 using Tapatalk
    you're welcome sir mangkas. I just reacted to your posted photos because in my opinion, the steel wool in the occ outlet will do more harm than good. but it will be still up to you if you think it can further restrict the escape of the oil to your turbo compressor. I used to drained my occ every 10k kms and all I get is a small quantity. I have not measured it kung ilang ml but that does not necessarily mean my occ is not doing its job. it does as long as may naiipon na oil. if konti lang ang oil that means your piston rings are still okay. if maraming oil ma-collect then it does not mean very effective ang occ. well, effective siya to catch the oil pero ang tanong bakit maraming oil?
    Jun 2007
    #5307
    Sir prince777 thanks sa pix.
    My mga t10 sir different length. Anu length nbili mo sir?
    Feb 2007
    #5308
    Yung sa front room lamp kailangan yung maiksi, others ok lang na mahaba.
    May 2012
    #5309
    Mga sir may question po ako. Newbie here. Ano po kaya problem ng monty ko. Kasi every time na nag cchange gear ako, parang may pumipito while slowly releasing the clutch and pumping the gas.
    Aug 2004
    #5310
    PLS HELP
    meron ba kayo alam na ROOF RACK for montero, yung diretso bolt na yung rack sa roof rail at wala na crossbar. meron kasi ako nakita at mas maganda tingnan kesa dun sa may nakausli na crossbar.
    if any of you guys know where to buy and how much..TIA
    Feb 2007
    #5311
    Quote Originally Posted by Elroi View Post
    PLS HELP
    Smart Rack by SHARK.
    http://www.sharkphil.com/montero_r.php#
    Contact them for pricing.
    Feb 2007
    #5312
    Aug 2004
    #5313
    thank you sir Prince777..
    i already inquired and 17k daw for montero. medyo pricey compared sa may crossbar na 3k-4k lang. hanap muna ako ng iba, baka sakali meron mas mura.
    Sep 2011
    #5314
    yup, and may tendency na magputol putol ang steel wool in the long run. I'd rather not put it in the outlet of the occ and put the risk na pwedeng mahigop ng compressor. we want as much as possible a clean air intake, that's why merong air filter, but to have the steel wool strands in a position that possibly ma-suck ng engine then imho it negates the purpose of the air filter. the purpose of the steel wool acts as a baffle or demister that helps in some way to separate the oil from the hot blow by gases and lessened the oil going to the compressor, but it can't be totally eliminated. even the provent and the flleetguard ventilation manager type occ's with filters can't get rid of all the oil, may traces pa rin. to be safe lang naman, better not have it in the outlet of your occ. even sir zix that installs most of the occ's here in tsikot does not advice or use the steel wool for the same reason na pwede mahigop ng makina yung steel wool. HTH
    AGREE ako bossing, actually mas kawawa yung blades nung VGT ni monty pag may nahigop na steel wool yan, parang si IRON MAN dun sa avenger movie, yun nga lng yung blades ang lagot.
    Apr 2012
    #5315
    After 2 good years....it's about time... 😊
    Aug 2005
    #5316
    Quote Originally Posted by wing211 View Post
    How much pa-install fmic sir?
    #5317
    Quote Originally Posted by leinahtan View Post
    dalhin mo lang sa shop sir, para magawa na natin yan tulad kay sir wing211.
    Apr 2012
    #5318
    Sir Zix...salamat...😆
    Apr 2012
    #5319
    Sir Zix...salamat...��
    wow! congrats sir wing211 sa bagong fmic...cooler intake air means more power!
    kay master zix...
    Aug 2005
    #5320
    Quote Originally Posted by zix888 View Post
    sir zix kindly pm details. thanks. na install ko na pala k&N air filter and cleaned the maf sensor * odo 11884km. Thanks sa advise.
2012 Montero Sport Owners
