Page 101 of 250 FirstFirst ... 5191979899100101102103104105111151201 ... LastLast
Results 2,001 to 2,020 of 5000
    Jun 2007
    #2001
    Quote Originally Posted by theparanoid View Post
    Hi sir...
    Im just surprised na 8.5 liters of oil ang ginamit sa inyong truck.
    Sabi nila 7L daw tlga ang limit. (while one 'reputable' casa uses 8L)
    But 8.5?
    --292. Marco
    Marco, sir RTS' strada is the 3.2 variant so Ok lang na 8-8.5 liters ang magamit. Sa 2.5 engine yung 7-7.5 liters na engine oil.
    #2002
    Quote Originally Posted by Djerms View Post
    Good days guys. Just want to ask, talamak pa rin ba ang SCV issues ng mitsu or did they come up with a solution already?
    Will the higher end deiesels (petron turbo and Shell v-power diesel) solve this problem?
    Thanks.
    Just to add to what S'theparanoid mentioned,
    1) try not to fill up gas when you see a tanker unloading newly delivered gasoline as this stirs up sediments in the bottom which could clog up your SCV.
    2) change fuel filters regularly or as most people here are recommending at least 5k kilometers before the scheduled maintenance replacement of the fuel filter. You may also try changing to aftermarket fuel filters though I personally haven't done this yet. You can check the threads regarding fuel filters.
    3) Just in case you still are worried about it, kasama naman po sa warranty yan.
    Please do note that these are just recommendations to possibly avoid problems earlier on in the life of your ride and are not absolutes. Problems with the SCV still does happen but not as rampant as before. I guess its also partly due to the kind and super helpful people of this forum kaya nakakaiwas na po sa problems.(Maraming salamat po!)
    I've been using Petron turbo on mine and at 15k, wala pa naman problems. There are also other gas stations that came out with a higher euro compliant diesel, though not as tested as with the big three. I believe most newer diesel models will sooner or later have problems with their SCV's because of the type of fuel we have or at least the type of maintenance the gas stations have of their fuel depots. Lastly, try not to worry too much about it and ENJOY your ride. Hope this has been helpful.
    Jun 2009
    #2003
    Hi,
    If you have 3.2L engine ,the 8.5 ltrs of oil is normal to be expected, sa bagong oil filter lang pag refill ng langis is already 1 ltr, about the engine warning I was temporary relieved dahil nag disappear, but last night bumalik na naman, pababayaan ko na lang muna as long as walang problema ang accelaration ko, kung baga immune na ako sa engine warning light.
    Regards & Safe Happy Driving
    RTS
    Mar 2004
    #2004
    Unfortunately sir, ive been reading posts here na V-Power Diesel na yung pinapakarga and yet they get the symptoms.
    (of course we must take with a grain of salt din naman yung mga pinopost dito, or opinions in general for that matter.)
    ang nababasa ko din dito, suggestions you can do regarding that issue:
    a. magpakarga sa stations na di binabaha
    b. stations na bago / 'new-ish' looking
    c. stations na madaming nagpapakarga
    d. and not having your tank go below 1/4 wont hurt either
    (and trying sticking with Petron or Shell lang, sabi ng iba)
    --292. Marco
    I used V-power since the unit was new, still got the SCV issue. Replaced already, even when the unit was still in it's first 1000 km, I could already sense that there was something different with the sound of the engine. IMO, it doesn't matter which fuel you use (as long as you stick with the big 3), if you have SCV issue, it will eventually present itself. Better to have the SCV symptoms come out while you're still under warranty.
    Jul 2011
    #2005
    Hello!
    Just wanted to ask if i have a 2.5L 4x2 strada, what gasoline company should i use? Caltex, Petron, Shell?
    Thanks for the insights.
    Jun 2009
    #2006
    Hi,
    about the SCV issue, pang apat na experienced ko ang engine warning light, the 2nd one is according to the casa they need to replace the SCV dahil it affected my acceleration, since it is still under warranty no sweat. The rest no change of SCV ,only cleaning of EGR, Exhaust manifold & other ancillary parts. It is not always the SCV is the culprit but other parts. Now na I'm off the warranty period & if in case I need to change the SCV, tumataginting na Php 5K plus ang kailangan. Im beginning to doubt the parameters set by the manufacturer dahil ibang pick up of different makers wala naman rampant problem na ganito.
    RTS
    Quote Originally Posted by braddypampy View Post
    Hello!
    The clean gas stations na hindi nababaha ang mas importante. But if ever, Shell or Petron priority mo.
    #2008
    +1 po. Doesn't really matter which so long as reputable po pagpapakargahan ninyo. Best kung medyo high traffic area para di palagi na stock yung mga gasolina nila.
    #2009
    Thanks guys.
    May nakapagsabi sakin from Strada Club na revised na daw ang SCV ng Strada from euro 4 to euro 2. Napansin ko din ito sa mga ads ng bnew strada.
    I also contacted one of my friends in the engineering department of Mitsu Cainta. He said that they already remedied the problem by making the SCV euro 2 compliant instead of euro 4. It has something to do with the holes daw wherein mas mailiit ang sa euro 4.
    It has nothing to do with the latak daw. Its really the viscosity of euro 2 fuel vs euro 4.
    Hope this helps.
    Thanks guys.
    Hope this helps.
    Sana nga sir.
    I guess MMPC will nt make a recall and change the SCV of previous models ah. Sana naman they do this para added bonus for making them a strong#2 player in our market.
    Jul 2011
    #2011
    Sir newbie here, Ano po ang ibig sabihin ng SCV valve sa Strada ? , iyon daw ang dapat palitan .
    Thank you po !
    #2012
    Suction control valve sir. AFAIK its part of the fuel system.
    Hope your replacement will be covered by warranty.
    Jan 2011
    #2013
    Thanks guys.
    Hope this helps.
    Would you know sir kung batches sold when nagsimula mapalitan into Euro 2 SCV?
    thanks...
    --292. Marco
    Jun 2009
    #2014
    Hi,
    Finally the word of wisdom pop out regarding the SCV problems we had endured for past & present, I wish the Mitsubishi people will offer some compensation in the form of changing the existing SCV free of charge, never mind yung nagastos natin for the past hindi na ibalik because of this SCV shortcomings. I hope some members of the club ,some what connected sa Mitsubishi will initiate action best for our interest. GO! GO! GO! GO!
    RTS
    +100, hope someone with close conection with MMPC will be able to help all those with euro 4 SCV.
    Quote Originally Posted by RTS View Post
    Hi,
    RTS
    #2016
    thanks...
    --292. Marco
    I'm not so sure sir. Ang sabi lang sakin is yung mga bagong lumabas so I guess the 2011 units are already revised. Pero sabi naman nung kakilala ko sa Mitsubishi daw pag may ganyang problema, lahat daw ng unreleased units papalitan.
    May 2008
    #2017
    Quote Originally Posted by mjlu View Post
    Sir you might also wanna consider a matte black carbon fiber sticker. I've seen it done on an Audi A4 and sobrang ganda. Yes it also had black rims. Only catch is that it cost the owner around 80k for the whole sticker lang.
    hmm pwede pero maybe yung "burnproof" na sticker linagay niya kaya mas mahal? try ko pa costing dito, only prob ko kasi dyan is if tatagal ba ang stickers hehe baka slowly matatangal...
    Thanks sa idea sir!
    Jul 2011
    #2018
    Sa mga 2011 Strada GLX owners ,question lang mga Sir , does this new VGT engine uses timing belt or timing chain ?
    Salamat po !
    Jun 2009
    #2019
    Hi,
    I had a chance to venture out at Binondo yesterday, napadaan ako sa Bosch brand na fuel filter, gustong gusto kong bumile sana but the problem no one can guarantee that it will fit to 4M41 (3.2L) engine even I gave them the OEM part nbr. , I wish someone can help me & others by posting yung part nbr. ng BOSCH fuel filter para next time sigurado na ako (price between the range of PHP 300-500) ., also they have variety of wipers, sayang what a chance.
    RTS
    Jul 2011
    #2020
    Thank you Sir .
2010 Mitsubishi Strada [continued 2]
