Results 1,291 to 1,300 of 1362
January 24th, 2014 11:46 PM #1291
Up up up up.........sa mga naka pag blanking egr ok naman po ba?....tnx
- Jan 2013
- 9
January 25th, 2014 12:23 AM #1292i had my egr blank.. so far so good.. less smoke, more responsive.. more than 5k na natakbo, no problem naman.
- Sep 2010
- 16
February 7th, 2014 08:58 AM #1293Anybody here having problems sa steering column nila? Im hearing knocking sound. Sabi ng SA ko sa steering column daw. Lailangan na palitan.
2005 Honda GD13 Jazz / 2010 Mitsubishi Montero GLS
- May 2009
- 9
February 7th, 2014 12:58 PM #1294
- May 2014
- 1
May 27th, 2014 01:37 PM #1295good noon montero brothers... sino pa sa inyo ang nakapintura sa kanilang engine cover?? anong klase na pintura gamit nyo??
- Jun 2013
- 244
June 12th, 2014 12:00 AM #1297goodpm, meron na sa inyo nag palit ng timing belt? ano kms nyo pinaltan? sabi kasi ng mekaniko ko 80,000kms mag palit na daw.72,000kms na kasi ako. sa labas ko na papagawa kasi wala na warranty. magkano inabot? ano ano pwede isabay para isang gawaan nalang?
June 12th, 2014 01:13 AM #1298
80k kms nga ang due ng timing belt replacement, yung iba sa 100k kms nagpapalit. no idea magkano timing belt. pwede mo isabay intake manifold cleaning kapag binaklas timing belt mo. since major PMS yan, sabay na din engine oil, atf, steering fluid, brake fluid, evaporator cleaning, oil/fuel/air filters...
- Jun 2009
- 95
June 12th, 2014 07:54 PM #1299nagpalit na ako ng timing belt *83k kms.parts aabot ng 14k to 15.d ko na maalaala.
Labor 1.8k
Sa el dorado cubao ako nagpagawa Look for Jay-mitsu mechanic expert
- Apr 2013
- 68
September 3rd, 2014 08:32 AM #1300Mga sirs ask ko lang po kung may way ba na lagi naka on ung signal lights ng monty natin kasabay ng park lights? I tried doing the old method of tapping the ground to the positive of the park light pero lahat na ng signal light umilaw. Even ung signal light sa gauge. Thanks
Posted via Tsikot Mobile App
To reset MzdConnect, Press Back, Navigation, Mute simultaneously. Sent from my SM-S901E using...
2016 Mazda MX-5 Miata
