Page 68 of 151 FirstFirst ... 185864656667686970717278118 ... LastLast
Results 1,341 to 1,360 of 3019
    #1341
    Quote Originally Posted by zix888 View Post
    Sir actually yung nitrogen ang maappreciate mo lang is yung medyo matagal ka bago magdagdag ng pressure ulit. Pero yung factor para maging sobra bumpy kasi naka ordinary air ka kumpara sa naka nitrogen is hindi rin naman masyado. I had been monitoring that behaviour of nitrogen since 06 mula ng naglow profile tires ako, nagkabit nako tire pressure monitors, even sa pinakamatagal na bihaye ko, maximum lang of 1.5psi ang lamang ng nitrogen in change in pressure compared sa ordinary. Lets say before biyahe, ordinary and nitrogen pressures both 30, after long drives of 5-6 hours ordinary 34psi and nitrogen 32.5psi, so para sabihin mo na malaking malaki ang diprensya, i dont believe that. If its free sa mga shops as okay lang, pero kung pricey, ordinary air ka na lang
    Actually, nung nag palit ako ng 20s sa montero napansin ko na medyo gumaangan yung steering niya nung nag pa-nitrogen ako. Not sure if talagang gumaang or psychological lang yun. Yung ride stayed the same. Although I seldom do long drives for me to notice yung difference... Long traffic everyday.
    Well will monitor yung impovement nung ride since I checked the tire pressures this evening. Medyo matigas nga yung harap at likod. Hopefully maging ok na siya. I'll use it tomorrow part masigurado ko na yun lang talaga yung problem.
    Thanks!
    #1342
    Quote Originally Posted by dg1110 View Post
    Thanks!
    Hehe, kahit psychological, eh kung pakiramdam ninyo gumaan yung steering wheel, well and good. Sana mag improve na yung ride nung oto mo sir
    Oct 2011
    #1343
    Quote Originally Posted by howard83 View Post
    hello po,
    sino po naka bili dito ASX during the Christmas promo nila? yung may free macbook air or ipad2 or low downpayment...
    kasi naka bili ako ASX pag december tapos ang tagal binigay nila ang free macbook air... until now dami pa reasons yung salesman ko... iba2x lang reason nya...
    san po tayo maka bili mga accessories para ASX? especially for the front grill, GLX lang kasi sa akin.
    ung package 2 ba kinuha mo bro? may kasama pang iPhone 4 and WD MyBook un sa bundle. Pwede naman palitan ng Mac yan kung wala ng available stock with other models.
    Oct 2011
    #1344
    Saan shop may available na nitrogen? how much per wheel?
    #1345
    i had my 26" wheels inflated with nitrogen at gtd merchandise sa banawe, charged me 100 each. nung naflat front right tire ko, ordinary na lang nilagay ko , so ginamit ko lang siya na yung 3 tires nitrogen, and yung isa ordinary air, dun ko nga napatunayan na pang alis guni-guni lang yung nitrogen. kaya dun sa 28" ko ordinary na nga lang inilagay ko, iwas hassle pa ng pagpunta sa banawe, anywhere pwede ka pa magpadagdag ng air.
    Oct 2011
    #1346
    hehe, parang placebo effect yan.
    #1347
    mayroon din naman magandang effect, like mas matagal na interval sa pag iinflate, plus in the long term naman, since mas mababa ang moisture content ng nitrogen, yung chance na kalawangin yung loob ng mags eh mas slim(kung steel mags, mostly light alloys na eh)
    Oct 2011
    #1348
    noted bro. pwede ba i-mix ung nitrogen sa ordinary air? I was thinking na in emergency cases when your tire is inflated with nitrogen tapos malambot ung tire in the middle of the road.
    Dec 2011
    #1349
    For tire Nitrogen believers, here's the fact;
    The air we use everyday composed of, 78% Nitrogen, 21% Oxygen & 1% other gases.
    The claim of Nitrogen for tire is not 100%, unless you are totally in a vacum from production to inflating into the car tire.
    Roughly, you just buy 15% Nitrogen for almost 400Pesos for 4tires.
    Finally, the benefits are????
    And you become reluctant not to check your tire regularly, later to find out your tire is 10Psi lower because of puncture...
    #1350
    hello po,
    Dapat Bro kasabay yan nung car mo, pero wala ka na magagawa ngayon kundi mag-follow up.
    hello po,
    Bro, dami na post dito tungkol dyan. I suggest you to back-read, mas marami kang matututunan!
    Anyway, winterpine is good compare sa casa. try mo # na ito, 09175180638.
    Oct 2011
    #1351
    Quote Originally Posted by F-14 View Post
    The benefits? from what i understand and read, lesser or totally no moisture due to the added nitrogen, thus oxygen is minimal to negligible.
    #1352
    Quote Originally Posted by rensom View Post
    May napansin pa ako sa harness… open siya. Kitang kita ang maliliit na wiring sa loob.. gusto ko lang malaman kung ganito rin bas a inyo? Pls. see the picture
    Try ko uli upload ng picture...
    Anyway, ganyan yata lahat ng ASX dito sa atin. pero ang GTA may cover.
    ayaw pa rin!!!
    #1353
    [img]http://s1181.photobucket.com/albums/x438/NoelSalisipan/?action=view&current=IMG_3110PB.jpg[img]
    Sep 2011
    #1354
    Quote Originally Posted by Noel Salisipan View Post
    Sensya na sir hijack ko muna to kasi naghahanap din ako accessories ng glx ko. Sinubukan ko tinext walang reply.
    Dec 2011
    #1355
    Still no real benefits!
    Less to zero O2 = less to no oxidation, for tire, for mags?
    Youre trying to protect the inside, how about the outside of the tire & mags?
    Less to zero O2 = almost stable pressure, for what?
    Under full load, long drives, short drives, with off road driving, city drives. These all need to adjust tire pressure accordingly if youre really concern with your tires.
    Using a Nitro unless you are a car racer or a jumbo jet fighter, really no substantial benefits to our car.
    Dec 2011
    #1356
    Quote Originally Posted by carofsteel View Post
    I suggest thru call is better as what I did before, thanks to this thread also.
    #1357
    Kaya advice ko nga sa mga tsikoteers na if free lang siya, okay lang, pero para magbayad pa just for that, pang alis guni-guni lang, huwag na lang. Pero kung free, definitely would use that kaysa ordinary air
    Oct 2011
    #1358
    That is also what I thought bro.
    #1359
    Anyways, mukhang ganun nga ata talaga ang ride ng ASX. Nanibago lang ako siguro. About the knocking sounds naman, they told me sa casa that there might be some problem in the multi link suspension at the rear (same daw sa naencounter sa GTA). They did some re-thighening and i-observe ko daw kung mawawala yung tunog. Sana mawala na siya.... Kung hindi pa rin mawala yun mukhang mag stay ako sa 17s hanggang maging ok to...
    Thanks mga Sir!
    Oct 2011
    #1360
    walang pinagkaiba ito sa mga engine treatment.
2010 Mitsubishi ASX Crossover
