Last edited by FoundOnRoadDead; December 11th, 2011 at 05:33 PM. Reason: replace text word
Actually bro, if lo bat, may key na nasa likod ng proximity transceiver na ipambubukas ng pinto..then, sa loob ng glove compartment may slot na you have to insert the transceiver, then you can start the car using the push button start/stop...It is how it works sa asx, dont know about other smart keys..maybe same din...
Just came from CLARK today. While on NLEX, my ASX reached 195kph but not yet it's vmax. My handy radar detector was keeping watch for any pesky speed traps along NLEX (but none was detected).
Sorry bro to confuse, pero di ko lang nareplayan kagabi to confirm about the literal key or the whole smart key dun sa may glove box.
Pero it happens na kailangan pala na yung smart key ang ilalagay.
In the first place, it doesnt make sense pag nag low bat yung smart key e sya pa rin ang key to start the engine!?Kala ko manual mode na pag dis-able na yung smart key, di pala.
Anyway, good thing napagusapan bago mag run out of battery yung smart key ko. Just in case e mas alam ko na gagawin ko!
Thanks for asking!
Oo nga bro.
Almost half a decade din nung mag lie low sa m/t car ko lalo na nung inabot ng 40+ ang gasoline, before kasi 24 lang.
Then, when I came back I bought this ASX. So, I was amazed & contented! (for now..)
Dati kasi, twin cam, 16valve, vtec...etc Di mo basta ramdam, not unless that you have a keen feeling.
Pero mgayon, paddle shifters, nav-sat, immobilizer... Kita at ramdam mo talaga.
I was in "D" and I wasn't selecting gears.
NOTE: CVT tranny = is a transmission that can change steplessly through an infinite number of effective gear ratios between maximum and minimum values. This contrasts with other mechanical transmissions that offer a fixed number of gear ratios. The flexibility of a CVT allows the driving shaft to maintain a constant angular velocity over a range of output velocities. This can provide better fuel economy than other transmissions by enabling the engine to run at its most efficient revolutions per minute (RPM) for a range of vehicle speeds. Alternatively it can be used to maximize the performance of a vehicle by allowing the engine to turn at the RPM at which it produces peak power. This is typically higher than the RPM that achieves peak efficiency
