Results 1 to 10 of 13
September 22nd, 2014 03:01 AM #1
Hello fellow tsikoters,
May quick question lang ako...
Due to recent typhoons and habagat...napasin ko ung bandang windows concrete walls namin inside the house ay nag momoist, pag hinawakan ay basa siya at some part nan magkakaair bubbles pero walang tubig...
Ano kaya pwede gawin dun? Ung exterior naman namin ay naka davies sun and rain 2 coats..
TIA
September 22nd, 2014 01:30 PM #2
is this wall below grade? is it on the east side? before painting the wall, it should have been primed and treated for waterproofing. however, you can still apply a coat of UGL water sealing coat available at ace hardware or you can use a waterproofing powder (sahara brand) mixed with mortar and plastered to the affected wall.
September 22nd, 2014 02:19 PM #3
makiki ride na ako TS...problema ko rin to yung isang side ng wall namin di lang talaga moist makikita mo yung takbo nung tubig.
Nitong nakaraan pumutok nanaman yung socket sa side na yun so sabi ko kay misis patayin na yung linya ng tuluyan.
September 22nd, 2014 02:29 PM #4
baka walang palitada.
mag moist yan at magtutubig sa loob kapag loob ng bahay lang
may palitada. yung likod wala. kaya papasukin ng tubig yan.
- Oct 2009
- 2,271
September 22nd, 2014 03:09 PM #5kung may palitata sa labas baka hindi nilagayan ng sahara or ung hinahalo sa semento para sa water proofing .kaya pumapasok din ung tubig sa semento.kung wall yan na sa gilid ng bahay nyo dapat may liso ung yerong manipis,
- Sep 2008
- 631
- Jul 2011
- 1,711
September 22nd, 2014 04:30 PM #7The problem is with your hollowblocks, ang nagamit sayo.ay ung tinipid (madaming buhangin kesa cement), kaya kahit maganda ang palitada mo mag crack pa din kasi mahina ung hollowblocks.
Sent via LaTE Network
September 22nd, 2014 04:52 PM #8
September 22nd, 2014 06:28 PM #9
Ty sa mga sumagot...may sahara po yung pag plaster sa labas lang po..then primed then 2 coats of davies rain and shine, planning to strip the paint inside then apply this bosny clear base coat that repels water raw then apply wall putty then primer before painting...will dat reaolve my problem? It only happen lang naman pag malakas talaga ulan pero pag tamang ulan lan wala siya
September 22nd, 2014 06:36 PM #10
di magtatagal magba bubbles pa din yan
dapat talaga may palitada loob at labas
ganyan din sa amin pag malakas lang na ulan nagbabubbles
pag mahina wala naman. yung likurang bahay namin di napalitadahan
ok naman dun sa kapitbahay namin sa likod kahit pangit view nila :D
kaso nga lang napasok tubig samin. ayaw na namin ipaayos kuntento na kami haha
I guess SMC has been doing a good job selling them
Car Sales Data (2024)
