so finally i got the.. the cheap MB ... i know i know .... i did not listen. (sabi na nga ni bos bob mag antay ng 123 diesel eh!) anyway I will somehow find the time and means to make it work for the car, so here goes the snags
THE BAD
1/ a/t shifting from "P' to "N" loud thud sound + jerking. "N" to "D" seems the same. when in "D" while driving ganun din only when may cases na nagsakto yung shift sa apak ko ng gas pedal
- is this tranny mounts or worst??
2/ the whole a/c system was originally R12 converted to I don't know what and was dome in a very bad taste, may pansit canton na wires sa ibabaw ng dryer ng a/c, worst yung center wood oanel binutas to give way to the makeshift a/c knobs!
3/ both front shocks busted
4/ there are cut wires everywhere in the engine bay
5/ fan clutch was disabled
6/ fuse box corroded and may mga naka jumper
7/ brakes feel spongy
8/ diasbled din ang hand brake
9/ dash lights always illuminated yung oil, reservoir, SRS, yung parang araw, at may tick tick sound na parang may open circuit sa loob ng cabin
10/ antenna was converted to japan ones, nawala yung side panel cover sa trunk
11/ driver seat does not move rearwards, is there a way to manually overrride this, hirao ako sa driving position ko
12/ only one key was given pudpod pa, di magamit sa driver side, pwede ba local alarm nalang i install?
13/ rear passenger cabin lights does not illuminate
14/ need to change the USV headlamps and grille
15/ door sidings upper edges starts to peel off
16/ sunvisor does not work
17/ lumalagatok yung rear passenger doors both during opening/closing
18/ nawala ang hood star
19/ no radio
20/ no medical kit
21/ spare tire was 14" ronal rims, anybody wants to swap with 15" steel rim?
1/ body is in very good shape, may kulang lang ng isang body liner about 2inches before the rear wheel well rh side
2/ kapapalit lang ng fuel regulator (talangka)
3/ kapapalit lang ng hydrovac
I really want na ayusin yung oto, pero in your opinion is it worth it? kindly advise reputable shops lalu na sa aircondition problems ko mukang ito ang malaking gastusan..
any clues or estimate price this will take is most welcome (ie. 50-70K, 100k up etc..) so i would know kung go or not to.
