Results 1 to 10 of 20
- Feb 2006
- 771
July 8th, 2011 10:56 AM #1mga sir ,
saan po ko pwede daan if galing ko Roxas Blvd going to SLEX?
pwede ba ko magleft turn from Roxas Blvd to Buendia o iikot pa ko para diretso sa SLEX?
July 8th, 2011 11:08 AM #2
san ba sa Roxas?? galing Luneta?? you can turn left sa Quirino.. diretso lang yun then right ka na sa SLEX..
- Jan 2011
- 262
July 8th, 2011 11:40 AM #3Sir, there's no left turn from roxas blvd to buendia. You can turn right at buendia and you'll see a u-turn slot there. Take it then go straight ahead until you reach south super highway, then turn right. Drive straight ahead and you'll reach SLEX.
Turning left at Quirino is also a viable option but after crossing Taft Avenue, you'll experience some moderate to heavy traffic because the road is being repaired. I'm not sure if they are already done with it though.
You'll also experience a bit of heavy traffic in Buendia because of the PUVs, pick your poison na lang..
Hope that helps!
- Feb 2006
- 771
July 8th, 2011 11:58 AM #4hi sirs Qwerty and Sir r1chmond ,
salamat po sa tip medyo dun nga ko isip kasi pag Quirino baybay pa ko Taft di ba? so i better take the Buendia and take the right turn U turn slot option siguro ksi dire diretso na lang .
salamat po sirs sa quick reply
- Feb 2006
- 771
July 8th, 2011 02:19 PM #7
dear google earth.......
galing ka cash & carry? langya lapit na ng slex dun. bakit mag roxas blvd ka pa.
para kang umikot nun palayo.
- Feb 2006
- 771
July 8th, 2011 03:54 PM #8sir ,
galing po ko ng Caloocan and travel ko by Roxas Blvd sana then going South and may pass by po sa C&C kasi baka SLEX daan ko , medyo di lang kasi ko sure sa mga pwede left turn and right turn esp sa Manila side and Roxas Blvd e, hirap naman po baka mahuli e ,promdi driver on the loose e
July 8th, 2011 04:03 PM #9
if you will go to Cash & Carry, along S. Super Hi-Way (aka Osmena hiway ba?) siya.
yun na yun....just go south, dugtong nun SLEX na. wala ng liku-liko.
- Jan 2011
- 262
July 8th, 2011 04:17 PM #10
high idle RPM at engine start
